MIT researchers have unveiled a portable, window‑sized device dubbed the atmospheric water harvesting window (AWHW) that can extract clean drinking water directly from air, even in death valley
    Probably this is paper https://arxiv.org/pdf/2201.10385
  • No electricity required.
    Means this dehumidifier produces even less water than the standard powered dehumidifier.
    Uses outside air.
    Will breed even nastier shit in the water than one inside a building.
    You know absolutely nothing about what makes water drinkable or how we as a society have already solved this problem
  • Might work better where it's more humid. Might bring humidity to more bearable levels if you have a lot of them?
    But when it's really humid, there's usually much better ways of getting water.
  • But when it's really humid, there's usually much better ways of getting water.
    But you also want to get humidity out of air so it's still a perk
  • Y'all, we're talking about condensate from a device specifically designed to capture water for drinking. We're not talking about drinking the water dripping from your AC. Ensuring this water is drinkable is remarkably simple.
    Not only that, but Clostridium botulinum only grows in anaerobic environments, so it isn't even a remote concern in this case. That's why you don't hear about it much outside of canned food or instances where it's purposefully cultivated for medical applications.
    Well, if this idea is so glorious, why is none of the large array of water harvesting devices that pop up multiple times a year ever deployed at scale?
    Easy answer: because they are all marketing bullshit that doesn't solve the actual problem and instead only exists to part investors from their cash.
  • Or is this a situation where you need at modern manufacturing facility to produce one?
    Probably the second one:
    The team also shaped the hydrogel into a dome-like origami array, like a sheet of bubble wrap. The unique structure increased surface area and maximized how much the material could swell so it would hold more water vapor. The team then sandwiched the gel between two glass panels roughly the size of a small window, both coated with a cooling chemical layer, and added tubing to collect the water.
    Assuming I'm wrong, you'd still need a ton of those for a single person. They got approximately 5.5oz in one night from one panel in death valley, but a quick Google says you need about 32oz per hour in high heat. You'd need just under 6 panels/person/hour you need water, which takes away from the idea that this is portable or really usable for hiking when you'd need like 80+ of these things to get anywhere close to having enough water for one day.
    5.5 wizards of oz?
  • These are called dehumidifiers and you should not drink the water that comes out of them.
    The condensed water is pure, yes. But dehumidifiers almost instantly become a breeding ground for all kinds of nasty shit. Nasty shit that is now in your ‘pure’ water.
    Edit: It's the same problem as the WaterSeer which is also a passive dehumidifier. This same idea comes up several times a year, yet you don't see them deployed in quantity anywhere. They simply don't work well. (The WaterSeer actually seems like a better design than what is in OP's article.)
    "Pure" is not a good thing when talking about water. Your body relies on minerals dissolved in drinking water. Also, water is a powerful solvent and if it isnt already saturated with minerals it will absorb calcium right out of your bones
    Ooohhh another dehumidifier!
    But no no no no, this time, THIS time, MIT is involved so it MUST be true, because MIT would never link it's mlname to yet another Sammy product, right?
    OOOHH, And this device will even get water out of desert air, you say? Like like all the other water out of dry air products that were all such obvious scams that any 15yo could use highschool physics to explain it to you?.
    Well call me sold, I'm all in in this one! By the way, I have this nice heat little bridge in my backyard, you'd LOVE it! Pay first, the. I'll show ya, promise!
    And just to make it really really clear: no, I haven't read the article and yes, it's a scam, and how do I know? Basic physics and, you know, seeing these devices come by every 2-4 years like clockwork and every damn time some university is funding it or attaching their names to it for some reason. I don't even need to read the article at this point.
    Here is a question: can universities please require that students have taken some basic physics courses before they allow them to start dumb scams like this?
    Edit: come at me Lemmy, down vote all you want, I'm still right
    Really?
    The waterseeer was an outright scam that never would have worked because physics, yet collecting millions in funding. And that wasn't the first on either
    This one is no difference, it's a scam.
  • Ooohhh another dehumidifier!
    I never understood why people keep falling for the 'dehumidifer will solve world water shortages' thing over and over. It's an old idea and there is damn good reason you don't see this 'obvious' solution deployed everywhere. (Check out the WaterSeer video if you would like to know more)
    13 Aufrufe
  • 50 Stimmen
    58 Aufrufe
    B
    They're also making electric cars that undercut the competition by about 20k in price. Of course they're running a loss on purpose.
  • Using Clouds for too long might have made you incompetent
    165 Stimmen
    87 Beiträge
    566 Aufrufe
    I was recruited as an R&D engineer by a company that was sales focused. It was pretty funny being recruited like a new sales hire: limo from the airport, etc. Limo driver didn't work direct for the company but she did a lot of work for them, it was an hour drive both ways to/from the "big" airport they used. She said most of the sales recruits she drove in were clueless kids, no idea how the world worked yet at all - gunning for a big commission job where 9/10 hires wash out within a year. At least after I arrived on-site I spent the day with my prospective new department, that was a pretty decent process. The one guy I didn't interview well with turned out to be the guy who had applied to the spot I was taking and had been passed over. As I was walking in on my first day he was just finishing moving his stuff out of the window-office desk he was giving up for me, into a cube. I can understand why he was a little prickly.
  • 263 Stimmen
    24 Beiträge
    126 Aufrufe
    glitchvid@lemmy.worldG
    Republicans are the biggest suckers there are. There's a reason as soon as the jig is up grifters pivot to conservative talking points.
  • Massaging the neck and face may help flush waste out of the brain
    237 Stimmen
    25 Beiträge
    148 Aufrufe
    D
    Segue into sexy time
  • How a Spyware App Compromised Assad’s Army
    41 Stimmen
    24 Aufrufe
    I guess that's why you pay your soldiers. In the early summer of 2024, months before the opposition launched Operation Deterrence of Aggression, a mobile application began circulating among a group of Syrian army officers. It carried an innocuous name: STFD-686, a string of letters standing for Syria Trust for Development. ... The STFD-686 app operated with disarming simplicity. It offered the promise of financial aid, requiring only that the victim fill out a few personal details. It asked innocent questions: “What kind of assistance are you expecting?” and “Tell us more about your financial situation.” ... Determining officers’ ranks made it possible for the app’s operators to identify those in sensitive positions, such as battalion commanders and communications officers, while knowing their exact place of service allowed for the construction of live maps of force deployments. It gave the operators behind the app and the website the ability to chart both strongholds and gaps in the Syrian army’s defensive lines. The most crucial point was the combination of the two pieces of information: Disclosing that “officer X” was stationed at “location Y” was tantamount to handing the enemy the army’s entire operating manual, especially on fluid fronts like those in Idlib and Sweida.
  • 323 Stimmen
    137 Beiträge
    686 Aufrufe
    F
    I think it would be best if that's a user setting, like dark mode. It would obviously be a popular setting to adjust. If they don't do that, there will doubtless be grease monkey and other scripts to hide it.
  • 2 Stimmen
    52 Aufrufe
    F
    IMO stuff like that is why a good trainer is important. IMO it's stronger evidence that proper user-centered design should be done and a usable and intuitive UX and set of APIs developed. But because the buyer of this heap of shit is some C-level, there is no incentive to actually make it usable for the unfortunate peons who are forced to interact with it. See also SFDC and every ERP solution in existence.
