Adblockers stop publishers serving ads to (or even seeing) 1bn web users - Press Gazette
  • 8 Stimmen
    12 Aufrufe
  • YouTube's Latest Update Shows That Online Monoculture Is Dead
    263 Stimmen
    124 Beiträge
    793 Aufrufe
    Then all hope is lost and there is absolutely no point in fighting, all it will do is annoy people who try to read your messages. If writing weird can have an impact on the world, I'm sure a lot of other things can too.
  • 311 Stimmen
    37 Beiträge
    207 Aufrufe
    Same, especially when searching technical or niche topics. Since there aren't a ton of results specific to the topic, mostly semi-related results will appear in the first page or two of a regular (non-Gemini) Google search, just due to the higher popularity of those webpages compared to the relevant webpages. Even the relevant webpages will have lots of non-relevant or semi-relevant information surrounding the answer I'm looking for. I don't know enough about it to be sure, but Gemini is probably just scraping a handful of websites on the first page, and since most of those are only semi-related, the resulting summary is a classic example of garbage in, garbage out. I also think there's probably something in the code that looks for information that is shared across multiple sources and prioritizing that over something that's only on one particular page (possibly the sole result with the information you need). Then, it phrases the summary as a direct answer to your query, misrepresenting the actual information on the pages they scraped. At least Gemini gives sources, I guess. The thing that gets on my nerves the most is how often I see people quote the summary as proof of something without checking the sources. It was bad before the rollout of Gemini, but at least back then Google was mostly scraping text and presenting it with little modification, along with a direct link to the webpage. Now, it's an LLM generating text phrased as a direct answer to a question (that was also AI-generated from your search query) using AI-summarized data points scraped from multiple webpages. It's obfuscating the source material further, but I also can't help but feel like it exposes a little of the behind-the-scenes fuckery Google has been doing for years before Gemini. How it bastardizes your query by interpreting it into a question, and then prioritizes homogeneous results that agree on the "answer" to your "question". For years they've been doing this to a certain extent, they just didn't share how they interpreted your query.
  • 61 Stimmen
    11 Beiträge
    59 Aufrufe
    K
    If you use LLMs like they should be, i.e. as autocomplete, they're helpful. Classic autocomplete can't see me type "import" and correctly guess that I want to import a file that I just created, but Copilot can. You shouldn't expect it to understand code, but it can type more quickly than you and plug the right things in more often than not.
  • The weaponization of Waymo
    147 Stimmen
    26 Beiträge
    146 Aufrufe
    F
    Not a warzone. A protest. A protest where over twice as many reporters have been assaulted and/or shot than waymo cars have burned.
  • 154 Stimmen
    137 Beiträge
    550 Aufrufe
    brewchin@lemmy.worldB
    If you're after text, there are a number of options. If you're after group voice, there are a number of options. You could mix and match both, but "where everyone else is" will also likely be a factor in that kind of decision. If you want both together, then there's probably just Element (Matrix + voice)? Not sure of other options that aren't centralised, where you're the product, or otherwise at obvious risk of enshittifying. (And Element has the smell of the latter to me, but that's another topic). I've prepared for Discord's inevitable "final straw" moment by setting up a Matrix room and maintaining a self-hosted Mumble server in Docker for my gaming buddies. It's worked when Discord has been down, so I know it works. Yet to convince them to test Element...
  • 92 Stimmen
    42 Beiträge
    187 Aufrufe
    G
    You don’t understand. The tracking and spying is the entire point of the maneuver. The ‘children are accessing porn’ thing is just a Trojan horse to justify the spying. I understand what are you saying, I simply don't consider to check if a law is applied as a Trojan horse in itself. I would agree if the EU had said to these sites "give us all the the access log, a list of your subscriber, every data you gather and a list of every IP it ever connected to your site", and even this way does not imply that with only the IP you could know who the user is without even asking the telecom company for help. So, is it a Trojan horse ? Maybe, it heavily depend on how the EU want to do it. If they just ask "show me how you try to avoid that a minor access your material", which normally is the fist step, I don't see how it could be a Trojan horse. It could become, I agree on that. As you pointed out, it’s already illegal for them to access it, and parents are legally required to prevent their children from accessing it. No, parents are not legally required to prevent it. The seller (or provider) is legally required. It is a subtle but important difference. But you don’t lock down the entire population, or institute pre-crime surveillance policies, just because some parents are not going to follow the law. True. You simply impose laws that make mandatories for the provider to check if he can sell/serve something to someone. I mean asking that the cashier of mall check if I am an adult when I buy a bottle of wine is no different than asking to Pornhub to check if the viewer is an adult. I agree that in one case is really simple and in the other is really hard (and it is becoming harder by the day). You then charge the guilty parents after the offense. Ok, it would work, but then how do you caught the offendind parents if not checking what everyone do ? Is it not simpler to try to prevent it instead ?
  • Mazda DMCA takedown of Open Source Home Assistant App
    108 Stimmen
    40 Aufrufe
    Soon this all will be much easier. From 12 of September we’re going into a new world of EU Data Act that forces all companies to allow third parties to communicate with iot devices. Which a car is. So soon Mazda will need to provide those APIs in an official way.
