Xfinity using WiFi signals in your house to detect motion
Oh boy, I can't wait for this new wave of paranoid customers claiming their wifi is watching them. Thanks, comcast.
Well, it very well can be used for exactly that.
Use your own modem and open source long range router
Do you have a recommendation?
I remember when MIT had a paper on this around 2000
Asus Rog GT-AX6000 with Merlin OS looks interesting.
Can check list of devices for OpenWRT also. -
If anything it's far more dangerous tech due to that. Let's say you live in 304; They know who lives in 303, 305, 203, 204, 205, 403, 404, 405, and the likelihood that your neighbors aren't as tech savvy and use ISP provided routers and modems means that they can use all of those sources to create a 3d image of you and your apartment with the proliferation of 2.4ghz and 5ghz to create a high resolution image that can track your lip movements and even your keystrokes on a computer. That basically just becomes a multi lens 3d camera recording at 5000 fps. The only way to avoid this is to faraday your entire apartment which ironically makes your signal much higher due to the deployment of countermeasures. The ol' "huh, interesting, what are they hiding?" approach.
What the actual Batman fuckery is this. I hope you are wrong or nobody is that motivated to do such things. Either way, scary! Where’s my tin foil hat?
fucking Batman
Can you use your own modem? I thought you had to use theirs?
I have successfully avoided cable up to this point, but I did use my own modem back when I used DSL. It wasn't advertised anywhere, but I just took the details from their modem and called support for the last bit I needed and used my own. It worked well, and I had my router be separate so I was able to just toss the modem when I got better service.
You need to use their modem quite often, but you don’t need to use their router. They’re usually “all in one” modem/router things these days, but they’re legally required to provide you with a modem in bridge mode if you ask — at that point, an Ethernet cable attached to their modem is effectively attached to the Internet, and you can put your own hardware inside (firewall, Wifi router, etc.).
While you need to connect to their IP gateway, you don’t need to use their DNS services or anything but their IP gateway service.
I don't think that's true. Their techs may claim that, but you van buy compatible modems online and find a helpful phone support person to get the details you need. Read up a bit on it first because they're not going to walk you through it.
You can use your own. But at every single point they're going to tell you that your brand new top of the line modem, is out of date and is probably the problem of any issue that you're having. They try so hard to gaslight customers in believing that you need to use their white labeled equipment. They want you to use their stuff and pay the fees so they can resell the Wi-Fi, and they have full control over your device.
I really fucking hope I'm just being paranoid, but this is absolutely possible given the already existing research. AI isn't going to launch nukes, it's just going to facilitate horrors beyond our wildest comprehension.
Edit: This article is from 9 years ago, before the current ai boom, we're fuckin' cooked.
https://www.inc.com/joseph-steinberg/how-wifi-lets-people-read-your-lips-identity-you-and-read-your-writing.html -
If a DOCSIS 3.0 modem still can't be saturated by the tier of internet someone is paying for, what advantage would 3.1 have?
Yeah I recently switched from cable to fiber (finally available), and prior I was using an old as fuck modem/router that capped at 500Mbps. My internet at fastest was 380. I rarely transfer files over the network, so figured why bother? (I did have Gen1 Google Mesh though to cover dead spots). I had a bit of a shopping splurge when I got fiber. Nothing crazy, just an upgraded mesh and a switch (Why the fuck does Frontier provide an ONT with 8 ethernet ports but only one is active?)
Can confirm, I live out in the countryside with only coax available, and a measly 1Gbit down 150Mbit up and 9 - 11ms ping. No caps.
Wait, that’s awesome and steady and reliable. Expensive sure but with heavy multiperson usage and no noticeable issues, I am wondering WTF you’re on about unless it’s some weird edge case?
Maybe you are referring to predatory business practices like oversubscribed lines? That’s not a technical problem.
Coax is generally a terrible and more expensive option, lower speeds all around and a worse ping. Especially now with fibre being so standard you shouldn't go for Coax if you have the choice.
Currently I do not have the choice so I have to pay 40 euro a month for 100mbps down and 25mbps up, with fibre I get symetrical gigabit for 45 euro a month or 400mbps symetrical for 40 euro. That's 16 times the upload speed for the same money.
And the first party with their coax (VodafoneZiggo) sells their coax as a fiber-cable. Which is just misleading bullshit.Heck the 5G modem I had was unstable at times, but the download was 100-200mbs and I paid 25 euro a month for that.
I still use coax because I buy internet from a reseller third party and this is what they have. I have 400/50 for 35$, which is a lot cheaper yhan the competitors. No reason for me to change.
Like I responded in the other comment, I can get fibre with 4 times the download speed and 16 times the upload speed for the same amount of money. And that is pretty standard since it is apparently a way cheaper thing to offer for companies.
I can't get anything cheaper than that because it's a price I got when the reseller started business and as long as I don't switch, I get that price.
Good for you that you can get better, but coax still has its place until internet providers up their game, but I won't hold my breath.
The show continuum used it too.
Mad at the concept, but at least it's off by default. Had Xfinity for 2 years and was running my own modem and router anyway, so I'm all set if I decide to switch back at this point
"cheap" is a relative term.
Nobody should be buying a DOCSIS 3.0 modem these days. They are obsolete and for some reason still being sold.
A decent DOCSIS 3.1 modem is at least $200. A Next Gen like S34 is at least $220. At least at the big blue big box store. And then you have to get your own wifi.
(However, that big blue store also will give you a 15% discount on any networking purchase if you recycle an old network device...I traded in an old modem but you should be able to find a switch or router at a thrift store and still come out ahead)
It pays for itself pretty quick (by not paying rental fees), but that doesn't necessarily make it cheap.
I absolutely prefer using my own equipment, and do...but it's also worth mentioning that in many markets, Xfinity removed data caps if you have a rented modem.
Rental? How much is rental?
While that may be "an option", 5G sucks compared to coax service.
Both are inferior to fiber by a long shot, but wired will always be better than cellular, which is limited spectrum and inconsistent.
As others have said, highly location dependent.
I switched from Xfinity to T-Mobile 4 years ago because tmobiles speed (raw speed) blew Xfinity out of the water...especially for upload. Latency and jitter suffered a bit but not enough to greatly effect voice calls. It didn't help my online gaming skills, but likely would've if I were a higher-caliber gamer. For me, the latency between chair and gamepad was much more impactful.
However Xfinity did some upgrades in my area and the roles have reversed so I'm back to Xfinity. Tmo is still absolutely usable, but Xfinity now offering 250mbps upload makes my mouth water.
