NodeBB v4.3.0 — Remote Categories are a go!
ActivityPub Test Kategorie
17 7 520
  • We're happy to announce the release of NodeBB v4.3.0, which contains native support for remote categories, bringing better integration with other NodeBB forums, WordPress, Lemmy, PieFed, mbin, and other "group-based" implementors on the ActivityPub network!
    What does this mean? 🤔
    It means that starting with this release, you will be able to "browse" to other categories simply by searching for them in your /world page. Just like with regular categories, you can "track" or "watch" remote categories — the former will show up in your /unread page, and the latter will also send notifications on new topics.
    Prior to this change, remote categories were rendered just like regular users, and there was some confusion over who was a user and who was a publisher.
    The integration with blog platforms like WordPress also mean you'll be able to use NodeBB kind of like a feed reader, with built-in notifications when new content is received. We're hoping to also extend this to support Ghost as well 🤞
    Some examples of categories loaded remotely in this NodeBB:
    Other notable changes in v4.3.0
    Chat allow/deny list 🗨
    There was some desire for more fine-grained support for allow/deny lists for the chat system. This is now available in v4.3.0. Per @baris:
    > Leaving allow list empty would mean anyone who is not in deny list can message you.
    > Leaving deny list empty would mean anyone who is in allow list can message you.
    > If both are empty everyone can message you.
    > Current restrictChat toggle can be turned into a toggle to disable chat completely.
    > Upgrade script can add the users following to the allow list if they have restrictChat turned on.
    Show number of topic watchers 👀
    You are now able to see the number of users watching a specific topic alongside the existing stats (posts, views, etc.)
    Accessibility updates
    • Avatar background colours are now selectable via keyboard navigation
    • Post drafts are now accessible via keyboard navigation
    ... and of course
    • Bug fixes and security updates
  • @Julian upgrading via
    git checkout v4.x
    git merge origin/v4.x
    only updates to v4.2.2
    git checkout v4.x
    @sweetp did you run git fetch?
  • @Julian thx!
    but now im getting this error:
    npm error code ERESOLVE
    npm error ERESOLVE could not resolve
    npm error
    npm error While resolving: nodebb@4.3.0
    npm error Found: eslint@8.57.1
    npm error node_modules/eslint
    npm error   peer eslint@"^6.0.0 || ^7.0.0 || >=8.0.0" from @eslint-community/eslint-utils@4.3.0
    npm error   node_modules/@eslint-community/eslint-utils
    npm error     @eslint-community/eslint-utils@"^4.2.0" from eslint@8.57.1
    npm error   peer eslint@"^7.32.0 || ^8.2.0" from eslint-config-airbnb-base@15.0.0
    npm error   node_modules/eslint-config-airbnb-base
    npm error     eslint-config-airbnb-base@"15.0.0" from eslint-config-nodebb@0.2.1
    npm error     node_modules/eslint-config-nodebb
    npm error       dev eslint-config-nodebb@"1.1.4" from the root project
    npm error   3 more (eslint-config-nodebb, eslint-plugin-import, nodebb-plugin-2factor)
    npm error
    npm error Could not resolve dependency:
    npm error dev @stylistic/eslint-plugin-js@"4.2.0" from the root project
    npm error
    npm error Conflicting peer dependency: eslint@9.25.1
    npm error   peer eslint@">=9.0.0" from @stylistic/eslint-plugin-js@4.2.0
    npm error   node_modules/@stylistic/eslint-plugin-js
    npm error
    npm error Fix the upstream dependency conflict, or retry
    npm error this command with --force or --legacy-peer-deps
    npm error to accept an incorrect (and potentially broken) dependency resolution.
    npm error
    npm error
    npm error For a full report see:
    npm error .../.npm/_logs/2025-05-01T04_18_44_098Z-eresolve-report.txt
    npm error A complete log of this run can be found in: .../.npm/_logs/2025-05-01T04_18_44_098Z-debug-0.log
    Error installing dependencies!
    message: Command failed: npm install --omit=dev
    stdout: null
    stderr: null
    .../NodeBB/src/cli/package-install.js:138
    		throw e;
    Error: Command failed: npm install --omit=dev
        at genericNodeError (node:internal/errors:983:15)
        at wrappedFn (node:internal/errors:537:14)
        at checkExecSyncError (node:child_process:882:11)
        at Object.execSync (node:child_process:954:15)
        at pkgInstall.installAll (.../NodeBB/src/cli/package-install.js:129:9)
        at Object. (.../NodeBB/src/cli/index.js:50:18)
        at Module._compile (node:internal/modules/cjs/loader:1734:14)
        at Object..js (node:internal/modules/cjs/loader:1899:10)
        at Module.load (node:internal/modules/cjs/loader:1469:32)
        at Function._load (node:internal/modules/cjs/loader:1286:12) {
      status: 1,
      signal: null,
      output: [ null, null, null ],
      pid: 2626367,
      stdout: null,
      stderr: null
  • @julian@community.nodebb.org I'm getting this error when running ./nodebb upgrade:
    stdout: null
    stderr: null
    /home/nodebb/nodebb/src/cli/package-install.js:138
    throw e;
  • If that's NodeBB 4.3.0 already, I think I've spotted a bug: BBcode mostly goes out as BBcode instead of converted into HTML which would then be rendered accordingly.
    Here on Hubzilla, in-line code and code blocks are rendered as such. But at least headlines, lists, images, quotes and links aren't; instead, I see the raw BBcode with no formatting. Hubzilla uses BBcode for formatting itself, but internally, and it doesn't expect BBcode to come in via ActivityPub.
  • @Julian thx!
    npm error
    npm error
    npm error
    npm error
    npm error
    npm error
    stdout: null
    stderr: null
    		throw e;
      status: 1,
      signal: null,
      pid: 2626367,
      stdout: null,
      stderr: null
    @sweetp Same error on my installation
    npm error
    npm error   peer eslint@"^6.0.0 || ^7.0.0 || >=8.0.0" from @eslint-community/eslint-utils@4.4.0
    npm error
    npm error
    npm error
    npm error
    npm error
    npm error /home/user_radforum/.npm/_logs/2025-05-01T08_35_32_095Z-eresolve-report.txt
    npm error A complete log of this run can be found in: /home/user_radforum/.npm/_logs/2025-05-01T08_35_32_095Z-debug-0.log
  • @julian I'm not sure if you know about this, but your entire post appears both as a content warning and the expanded post, both contain the exact same text. Is that issue known? btw, I'm on go to social, so perhaps that could be a factor too?
  • Those having an issue with eslint, can just remove the node_modules folder in their nodebb folder and run ./nodebb upgrade again.
  • @baris it's still crashing for me
    $ rm -rf node_modules
    $ ./nodebb upgrade
    npm error
    npm error
    npm error
    npm error
    npm error
    npm error
    npm error .../.npm/_logs/2025-05-01T13_28_21_731Z-eresolve-report.txt
    npm error A complete log of this run can be found in: .../.npm/_logs/2025-05-01T13_28_21_731Z-debug-0.log
    stdout: null
    stderr: null
    .../NodeBB/src/cli/index.js:65
    		throw e;
        at Object. (.../NodeBB/src/cli/index.js:18:19)
      status: 1,
      signal: null,
      pid: 2729523,
      stdout: null,
      stderr: null
    Node.js v23.11.0
  • Do you have eslint-config-airbnb-base in your package.json? We don't use that dependency anymore so it shouldn't be in package.json.
  • @baris nope:
        "name": "nodebb",
        "license": "GPL-3.0",
        "description": "NodeBB Forum",
        "version": "4.3.0",
        "homepage": "https://www.nodebb.org",
        "repository": {
            "type": "git",
            "url": "https://github.com/NodeBB/NodeBB/"
        "main": "app.js",
        "scripts": {
            "start": "node loader.js",
            "lint": "eslint --cache ./nodebb .",
            "test": "nyc --reporter=html --reporter=text-summary mocha",
            "coverage": "nyc report --reporter=text-lcov > ./coverage/lcov.info",
            "coveralls": "nyc report --reporter=text-lcov | coveralls && rm -r coverage"
        "husky": {
            "hooks": {
                "pre-commit": "npx lint-staged",
                "commit-msg": "npx commitlint -E HUSKY_GIT_PARAMS"
        "lint-staged": {
            "*.js": [
                "eslint --fix"
        "dependencies": {
            "@adactive/bootstrap-tagsinput": "0.8.2",
            "@fontsource/inter": "5.2.5",
            "@fontsource/poppins": "5.2.5",
            "@fortawesome/fontawesome-free": "6.7.2",
            "@isaacs/ttlcache": "1.4.1",
            "[@nodebb](https://community.nodebb.org/user/nodebb)/spider-detector": "2.0.3",
            "@popperjs/core": "2.11.8",
            "@resvg/resvg-js": "2.6.2",
            "@socket.io/redis-adapter": "8.3.0",
            "@textcomplete/contenteditable": "0.1.13",
            "@textcomplete/core": "0.1.13",
            "@textcomplete/textarea": "0.1.13",
            "ace-builds": "1.40.1",
            "archiver": "7.0.1",
            "async": "3.2.6",
            "autoprefixer": "10.4.21",
            "bcryptjs": "3.0.2",
            "benchpressjs": "2.5.5",
            "body-parser": "2.2.0",
            "bootbox": "6.0.3",
            "bootstrap": "5.3.5",
            "bootswatch": "5.3.5",
            "chalk": "4.1.2",
            "chart.js": "4.4.9",
            "cli-graph": "3.2.2",
            "clipboard": "2.0.11",
            "commander": "13.1.0",
            "compare-versions": "6.1.1",
            "compression": "1.8.0",
            "connect-flash": "0.1.1",
            "connect-mongo": "5.1.0",
            "connect-multiparty": "2.2.0",
            "connect-pg-simple": "10.0.0",
            "connect-redis": "8.0.3",
            "cookie-parser": "1.4.7",
            "cron": "4.3.0",
            "cropperjs": "1.6.2",
            "csrf-sync": "4.1.0",
            "daemon": "1.1.0",
            "diff": "7.0.0",
            "esbuild": "0.25.3",
            "express": "4.21.2",
            "express-session": "1.18.1",
            "express-useragent": "1.0.15",
            "fetch-cookie": "3.1.0",
            "file-loader": "6.2.0",
            "fs-extra": "11.3.0",
            "graceful-fs": "4.2.11",
            "helmet": "7.2.0",
            "html-to-text": "9.0.5",
            "imagesloaded": "5.0.0",
            "ioredis": "5.6.1",
            "ipaddr.js": "2.2.0",
            "jquery": "3.7.1",
            "jquery-deserialize": "2.0.0",
            "jquery-form": "4.3.0",
            "jquery-serializeobject": "1.0.0",
            "jquery-ui": "1.14.1",
            "jsesc": "3.1.0",
            "json2csv": "5.0.7",
            "jsonwebtoken": "9.0.2",
            "lodash": "4.17.21",
            "logrotate-stream": "0.2.9",
            "lru-cache": "10.4.3",
            "mime": "3.0.0",
            "mkdirp": "3.0.1",
            "mongodb": "6.16.0",
            "morgan": "1.10.0",
            "mousetrap": "1.6.5",
            "multiparty": "4.2.3",
            "nconf": "0.13.0",
            "nodebb-plugin-2factor": "7.5.9",
            "nodebb-plugin-composer-default": "10.2.49",
            "nodebb-plugin-dbsearch": "6.2.15",
            "nodebb-plugin-emoji": "6.0.2",
            "nodebb-plugin-emoji-android": "4.1.1",
            "nodebb-plugin-imgur": "^4.1.0",
            "nodebb-plugin-markdown": "13.1.1",
            "nodebb-plugin-mentions": "4.7.3",
            "nodebb-plugin-ntfy": "1.7.7",
            "nodebb-plugin-soundpack-default": "^3.0.1",
            "nodebb-plugin-spam-be-gone": "2.3.1",
            "nodebb-plugin-web-push": "0.7.3",
            "nodebb-rewards-essentials": "1.0.1",
            "nodebb-theme-harmony": "2.1.11",
            "nodebb-theme-harmony-sweetp": "git+https://git@github.com/sweetppro/nodebb-theme-sweetp.git#master",
            "nodebb-theme-lavender": "7.1.18",
            "nodebb-theme-peace": "2.2.40",
            "nodebb-theme-persona": "14.1.9",
            "nodebb-theme-slick": "2.0.2",
            "nodebb-theme-vanilla": "12.1.19",
            "nodebb-widget-essentials": "7.0.36",
            "nodemailer": "6.10.1",
            "nprogress": "0.2.0",
            "passport": "0.7.0",
            "passport-http-bearer": "1.0.1",
            "passport-local": "1.0.0",
            "pg": "8.15.6",
            "pg-cursor": "2.14.6",
            "postcss": "8.5.3",
            "postcss-clean": "1.2.0",
            "progress-webpack-plugin": "1.0.16",
            "prompt": "1.3.0",
            "rimraf": "5.0.10",
            "rss": "1.2.2",
            "rtlcss": "4.3.0",
            "sanitize-html": "2.16.0",
            "sass": "1.87.0",
            "satori": "0.12.2",
            "semver": "7.7.1",
            "serve-favicon": "2.5.0",
            "sharp": "0.32.6",
            "sitemap": "8.0.0",
            "socket.io": "4.8.1",
            "socket.io-client": "4.8.1",
            "sortablejs": "1.15.6",
            "spdx-license-list": "6.10.0",
            "terser-webpack-plugin": "5.3.14",
            "textcomplete": "0.18.2",
            "textcomplete.contenteditable": "0.1.1",
            "timeago": "1.6.7",
            "tinycon": "0.6.8",
            "toobusy-js": "0.5.1",
            "tough-cookie": "5.1.2",
            "validator": "13.15.0",
            "webpack": "5.99.7",
            "webpack-merge": "6.0.1",
            "winston": "3.17.0",
            "workerpool": "9.2.0",
            "xml": "1.0.1",
            "xregexp": "5.1.2",
            "yargs": "17.7.2",
            "zxcvbn": "4.4.2"
        "devDependencies": {
            "@apidevtools/swagger-parser": "10.1.0",
            "@commitlint/cli": "19.8.0",
            "@commitlint/config-angular": "19.8.0",
            "coveralls": "3.1.1",
            "@eslint/js": "9.25.1",
            "@stylistic/eslint-plugin-js": "4.2.0",
            "eslint-config-nodebb": "1.1.4",
            "eslint-plugin-import": "2.31.0",
            "grunt": "1.6.1",
            "grunt-contrib-watch": "1.1.0",
            "husky": "8.0.3",
            "jsdom": "26.1.0",
            "lint-staged": "15.5.1",
            "mocha": "11.1.0",
            "mocha-lcov-reporter": "1.3.0",
            "mockdate": "3.0.5",
            "nyc": "17.1.0",
            "smtp-server": "3.13.6"
        "bugs": {
            "url": "https://github.com/NodeBB/NodeBB/issues"
        "engines": {
            "node": ">=18"
        "maintainers": [
                "name": "Julian Lam",
                "email": "julian@nodebb.org",
                "url": "https://github.com/julianlam"
                "name": "Barış Soner Uşaklı",
                "email": "baris@nodebb.org",
                "url": "https://github.com/barisusakli"
        "nyc": {
            "exclude": [
                "src/upgrades/*",
                "test/*"
        "resolutions": {
            "*/jquery": "3.7.1"
        "optionalDependencies": {
            "sass-embedded": "1.87.0"
  • What happens when you try the below
    npm r eslint-config-airbnb-base
    npm r eslint-config-nodebb
    rm -rf node_modules/
    npm i
  • @baris same issue unfortunately:
    Dependencies outdated or not yet installed.
    Installing them now...
    npm error
    npm error
    npm error
    npm error
    npm error
    npm error
    npm error .../.npm/_logs/2025-05-01T13_56_37_050Z-eresolve-report.txt
    npm error A complete log of this run can be found in: .../.npm/_logs/2025-05-01T13_56_37_050Z-debug-0.log
    stdout: null
    stderr: null
    		throw e;
      status: 1,
      signal: null,
      pid: 2732894,
      stdout: null,
      stderr: null
    Node.js v23.11.0
  • Try removing package-lock.json as well see what happens.
    rm package-lock.json
    npm i
  • @baris that worked!
    @esoteric_programmer@social.stealthy.club that's likely because GtS handles summary as a content warning for everything. The whole summary and content warning business is in flux right now, so hopefully a standard will be set soon.
