The "standard" car charger is usually overkill—but your electrician might not know that [32:26]
Highly recommend Technology Connections for anyone interested in easy to understand, relatable breakdown videos of technology.
could this be an article instead of a video? I'm not spending 32 minutes watching this, tbh
This has to be my favorite thing about Jeff Geerling vs other YouTube channels, he'll make an accompanying blog post to go with each of his main channel videos that is effectively an annotated text version of the video with appropriately embedded images and links.
You should give it a shot. The dudes videos are super captivating.
Yes. In a nutshell it's "if you don't know about electric cars, here's some information you probably don't know as well"
This is how I feel about any video longer than a short gif
Good video. Accurate information.
Two notes:
For North American homes: I agree with the overlooked value of a downrated circuit for EV charging, but I don't think he talked about a possibly better option for downrating: Using an existing 120v circuit (at whatever current rating) already wired in the garage . Remove the outlet, install EVSE (charger), and swap the breaker for a 240v one (at a current rating matching the original. So if you have a 120v 15A circuit (white romex) you can use the exact same wire for a 240v at 15A. If you have a 20A (yellow romex) you would end up with a 240v 20A. You get more than double the speed of charging with zero new wires added, only changing the breaker and removing the old outlets. Note: If you have multiple outlets in your garage all fed from this same circuit, this would mean all of your outlets in the garage are now 240v and not usable for regular 120v items.
He didn't like Smart chargers. Thats a valid opinion, but smart chargers can do some nice things that I like. Some will also talk to each other if you have two chargers, such as if you have two EVs. They can be configured to share the same wire to the breaker box, so you can plug both cars in at night, one car will charge, then when that is complete, the other will charge automatically without having to unplug one car and then plug in the other. It will charge the least charged car first ensuring the best balance of charge to both cars assuming both cars can't be charged to full in one night. If you have solar panels, some smart chargers can talk to the solar system and be instructed to only charge when there is excess power that would otherwise go to waste. It can do this automatically so if clouds go overhead and not enough juice is available from the sun, the charging stops. As soon as the clouds clear and there is an excess again, charging resumes automatically. For outdoor charging, you can also configure most Smart chargers to only charge you authorized cars. So you don't need to worry about someone rolling into your driveway when you're not home (or a bad neighbor) and running up your electricity bill.
Two notes:
A 240V 20amp circuit I think would meet the needs of 99% of commuters in the US. If your average miles/kWh is around 3.3 and you're charging at 80% of the 20amp breaker limit (as you should be), even factoring in 10% losses in power transmission, you're still charging somewhere around 11 miles per hour. Easy 100+ miles overnight with zero infrastructure change outside of a couple wire nuts and a cheap charger. Hell, depending on local codes, you might get away with slapping in a nema 6-20 receptacle to make it even easier...
Two notes:
Running more than one outlet on a 220 circute is generally against us codes. It will work but don't do it.
I have a phev with only 30 miles of range - ofen I get home with a nearly dead battery and need to leave again soon - I want faster charging. I'm sure someone with 200 miles of range can be fine on 110 volt slow charging as there likely enough time over a week that it works.
I think “might be overkill” would be a better title and position than “usually overkill.”
There is absolutely a subset of EV drivers that could get by with a level 1 charger (ignoring time of day rates), but most people would fall behind anytime they drive further than the average number of miles. Sure, taking 10 hours to recharge your Chevy Bolt overnight when you’ve driven 40 miles is doable; 64 hours when you’ve returned home from a longer trip isn’t.
I own a PHEV, and installing a level 2 charge has been one of the best quality of life and financial changes.
Yeah I don’t need to refill my battery in 2 hours, but it’s nice to be able to meaningfully top off between errands to make the most of a small PHEV battery.
I agree with this youtube comment:
As an electrician (in Australia), I agree with your basic premise. However, if you are asking me to install an EV charger, unless you tell me “I want it to charge slowly with a limited current capacity”, I am going to assume it is to charge an EV under ALL situations - fast to slow, for whoever may drive one today or in the future, even with a potential new homeowner. We generally do our work with the priority order (1) safety - nobody gets an electric shock and nothing catches fire; (2) avoidance of nuisance i.e. the thing you just installed doesn’t work and keeps tripping the breaker
(3) avoiding needing replacement electrical work for at least 25 - 50 years
Also I live in a townhouse with no garage. Our charger is between the neighborhood sidewalk and our parking spaces, so I'd prefer keeping it plugged in as little as possible to minimize any issues with foot traffic (neighbors, delivery people, garbage pickup, etc). I've seen other townhouse EV owners literally run an extension cable over the sidewalk to do an L1 charge for their EV and that's just asking for trouble.
I think #1 is suggesting to move the neutral over to another hot phase and change the outlet to a 240v nema 6/three prong (I think) with two hots and a ground instead of the 4 prong.
The 240v at the same amps gives you higher watts so faster charging without an expensive new conductor. I'm
What kind of range do you have on that? I've been debating installing a l2 charger because overnight charging is usually good enough. I tend to get about 15-20 miles range tops on pure electric.
Yep the difference for our setup was going from 12-18 hour full charge times (Level 1) to about 6 hours on Level 2. L1 charger could only put out 12 amps at 120v, and while the L2 charger can do up to 50A of 240v power, our vehicle can only use about a third of that capacity at max draw.
So as the video's topic covers, we didn't need a 50A circuit for Level 2 charging on our limited vehicle. But I put in a full 50A circuit anyway so now I can eventually upgrade our other car to electric or PHEV and be ready for whatever those need.
Two notes:
#1 is a terrible idea if you ever need to hire an electrician in the future, plan on selling your house, etc. The National Electric Code prohibits using white, green, or grey wire for a hot/load connection. The 120V cable will contain a black wire for the hot connection, white for neutral, and green for ground. To properly convert it to 240V you would need a cable that consists of black & red wires for the two 120V legs.
If your home ever suffered an electrical fire then this sort of jury rigging is precisely the sort of thing any competent insurance inspector would spot, and insurance carriers would deny coverage for since it clearly isn’t code compliant, which means a licensed electrician didn’t install it and it wasn’t properly inspected.
The problem with #1 is that most garages only have one circuit for the outlets AND the garage door opener. Moving to 240v would fry the opener.
Two notes:
Changing a 120v line over to 240 is likely also against code even if the physical cable can handle it. 120V cable is typically white/black/green, and the electrical code prohibits using the white one as a hot leg. That’s why 240V cable of the same AWG is red/black/green. The red & black legs both carry 120V.
Simple Wikiclaudia: Chrome extension that finds a simple.wikipedia.org version of any wiki article. If one exists, click to open it; otherwise, it uses Claude or ChatGPT to simplify it.
China New Internet ID System a Threat to Online Expression: Netizens will require IDs to go on the internet. For now this is voluntary, but there are signs it will not remain that way for long.
