Thanks. I have to admit I haven't worked on perovskite since then, so my knowledge is surely very outdated.
I found this paper that seems so address this question:
https://www.sciencedirect.com/science/article/abs/pii/S0026265X23005428
perovskites demonstrate exceptional photodetection abilities characterized by high sensitivity and fast response times, rendering them ideal for the development of optical sensors for medical diagnostics and environmental monitoring. Additionally, they hold promise in gas sensing applications, detecting specific gases with high sensitivity and opening up a wide range of potential applications in industrial process control and environmental monitoring. Although perovskite materials have gained attention due to their unique properties, their stability in the presence of moisture or oxygen remains a significant challenge and is an active area of research.
this study provides a comprehensive evaluation of recent applications of perovskite materials-based sensors. Specifically, the focus is on chemiresistive gas sensors based on perovskite oxides and fluorescence/photoelectrochemical sensors based on halide perovskitesThis is actually a really good paper, but i'm skimming it to find the references to the stability of peroskite...but i'm not good at doing this on a mobile device.
You can say goodbye to live view then
No, the mirror reflects to the view finder untill you press the shutter, then it moves thr mirror to expose the photo sensor and then back.
In English they're called reflex cameras. No one makes them now.
I mean no more live view via the screen
The Meta AI app is a privacy disaster: Meta's AI App ‘Discover’ Feed Publicly Exposes Private Chats Without Users Knowing.
Computer says no: Impact of automated decision-making on human life; Algorithms are deciding whether a patient receives an organ transplant or not; Algorithms use in Welfare, Penalise the poor.
