They use stacked transparent color sensors, like Foveon camera sensors used to.
In numerous experiments, the researchers put the two prototypes, which differ in their readout technology, through their paces. Their results prove the advantages of perovskite: the sensors are more sensitive to light, more precise in color reproduction and can offer a significantly higher resolution than conventional silicon technology.
The fact that each pixel captures all the light also eliminates some of the artifacts of digital photography, such as demosaicing and the moiré effect.
Does it matter if there's a ultraviolet and IR filter on it? Is it functionally equivalent to darkness?
No idea. IIRC the problem comes from chemical instability i.e., even when properly encapsulated, the methylammonium just evaporates/decompose and you're left with a nice lead iodide layer. Can't say if it's better now. It's been quite a feew years ago.
No idea.
Thanks. I have to admit I haven't worked on perovskite since then, so my knowledge is surely very outdated.
I found this paper that seems so address this question:
https://www.sciencedirect.com/science/article/abs/pii/S0026265X23005428
perovskites demonstrate exceptional photodetection abilities characterized by high sensitivity and fast response times, rendering them ideal for the development of optical sensors for medical diagnostics and environmental monitoring. Additionally, they hold promise in gas sensing applications, detecting specific gases with high sensitivity and opening up a wide range of potential applications in industrial process control and environmental monitoring. Although perovskite materials have gained attention due to their unique properties, their stability in the presence of moisture or oxygen remains a significant challenge and is an active area of research.
this study provides a comprehensive evaluation of recent applications of perovskite materials-based sensors. Specifically, the focus is on chemiresistive gas sensors based on perovskite oxides and fluorescence/photoelectrochemical sensors based on halide perovskitesThis is actually a really good paper, but i'm skimming it to find the references to the stability of peroskite...but i'm not good at doing this on a mobile device.
Meta(Facebook) and Yandex apps silently de-anonymize users’ browsing habits without consent.
Time reporters were able to use Google's AI to make convincing videos of Muslims setting fire to a Hindu temple; Chinese researchers handling a bat in a wet lab; and election workers shredding ballots
Australia could tax Google, Facebook and other tech giants with a digital services tax – but don’t hold your breath
Pope Betting Odds: Bettors Lose Millions Predicting the New Pope as Polymarket Edge Fizzles Out
