Trump may launch Trump-branded mobile phone and a wireless service that could compete with the likes of Verizon, AT&T, and T-Mobile.
  • 72 Stimmen
    12 Beiträge
    Because that worked so well for South Korea
    3 Aufrufe
  • 183 Stimmen
    39 Beiträge
    7 Aufrufe
    H
    https://archive.org/details/swgrap
  • 8 Stimmen
    3 Aufrufe
    B
    [image: 8978adf5-b473-470c-9f21-62a31e2fbc77.gif]
  • 20 Stimmen
    3 Aufrufe
    Fantastic! Me and my 7 legs tank you so much!
  • 4 Stimmen
    3 Aufrufe
    Epic is a piece of shit company. The only reason they are fighting this fight with Apple is because they want some of Apple’s platform fees for themselves. Period. The fact that they managed to convince a bunch of simpletons that they are somehow Robin Hood coming to free them from the tyrant (who was actually protecting all those users all along) is laughable. Apple created the platform, Apple managed it, curated it, and controlled it. That gives them the right to profit from it. You might dislike that but — guess what? Nobody forced you to buy it. Buy Android if Fortnight is so important to you. Seriously. Please. We won’t miss you. Epic thinks they have a right to profit from Apple’s platform and not pay them for all the work they did to get it to be over 1 billion users. That is simply wrong. They should build their own platform and their own App Store and convince 1 billion people to use it. The reason they aren’t doing that is because they know they will never be as successful as Apple has been.
    5 Aufrufe
    I think the principle could be applied to scan outside of the machine. It is making requests to 127.0.0.1:{port} - effectively using your computer as a "server" in a sort of reverse-SSRF attack. There's no reason it can't make requests to 10.10.10.1:{port} as well. Of course you'd need to guess the netmask of the network address range first, but this isn't that hard. In fact, if you consider that at least as far as the desktop site goes, most people will be browsing the web behind a standard consumer router left on defaults where it will be the first device in the DHCP range (e.g. 192.168.0.1 or 10.10.10.1), which tends to have a web UI on the LAN interface (port 8080, 80 or 443), then you'd only realistically need to scan a few addresses to determine the network address range. If you want to keep noise even lower, using just 192.168.0.1:80 and 192.168.1.1:80 I'd wager would cover 99% of consumer routers. From there you could assume that it's a /24 netmask and scan IPs to your heart's content. You could do top 10 most common ports type scans and go in-depth on anything you get a result on. I haven't tested this, but I don't see why it wouldn't work, when I was testing 13ft.io - a self-hosted 12ft.io paywall remover, an SSRF flaw like this absolutely let you perform any network request to any LAN address in range.
    6 Aufrufe
    Forgive me for not explaining better. Here are the terms potentially needing explanation. Provisioning in this case is initial system setup, the kind of stuff you would do manually after a fresh install, but usually implies a regimented and repeatable process. Virtual Machine (VM) snapshots are like a save state in a game, and are often used to reset a virtual machine to a particular known-working condition. Preboot Execution Environment (PXE, aka ‘network boot’) is a network adapter feature that lets you boot a physical machine from a hosted network image rather than the usual installation on locally attached storage. It’s probably tucked away in your BIOS settings, but many computers have the feature since it’s a common requirement in commercial deployments. As with the VM snapshot described above, a PXE image is typically a known-working state that resets on each boot. Non-virtualized means not using hardware virtualization, and I meant specifically not running inside a virtual machine. Local-only means without a network or just not booting from a network-hosted image. Telemetry refers to data collecting functionality. Most software has it. Windows has a lot. Telemetry isn’t necessarily bad since it can, for example, help reveal and resolve bugs and usability problems, but it is easily (and has often been) abused by data-hungry corporations like MS, so disabling it is an advisable precaution. MS = Microsoft OSS = Open Source Software Group policies are administrative settings in Windows that control standards (for stuff like security, power management, licensing, file system and settings access, etc.) for user groups on a machine or network. Most users stick with the defaults but you can edit these yourself for a greater degree of control. Docker lets you run software inside “containers” to isolate them from the rest of the environment, exposing and/or virtualizing just the resources they need to run, and Compose is a related tool for defining one or more of these containers, how they interact, etc. To my knowledge there is no one-to-one equivalent for Windows. Obviously, many of these concepts relate to IT work, as are the use-cases I had in mind, but the software is simple enough for the average user if you just pick one of the premade playbooks. (The Atlas playbook is popular among gamers, for example.) Edit: added explanations for docker and telemetry
