My son's surgeon told me about the evolution of one particular cardiac procedure. Most of the "good" doctors were laying many stitches in a tight fashion while the "lazy" doctors laid down fewer stitches a bit looser. Turns out that the patients of the "lazy" doctors had a better recovery rate so now that's the standard procedure.
Sometimes divergent behaviors can actually lead to better behavior. An AI surgeon that is "lazy" probably wouldn't exist and engineers would probably stamp out that behavior before it even got to the OR.
deleted by creator
know what? let's just skip the middleman and have the CEO undergo the same operation. you know like the taser company that tasers their employees.
can't have trust in a product unless you use the product.
Hold on 3P0...you gotta little piece of human stuff stuck on your right end effector clamp top hinge pin. There, all good! Continue!
Eliminating room for error, not to say AI is flawless but that is the goal in most cases, is a good way to never learn anything new. I don't completely dislike this idea but I'm sure it will be driven towards cutting costs, not saving lives.
deleted by creator
Nah, just a thorough reproduction of the consequences of that wrong.
Not specifically but I think the guidance is applicable to most incisions of the heart. I think the fact that it's a muscular and constantly moving organ makes it differently than something like an epidermal stitch.
And my post isn't to say "all mistakes are good" but that invariablity can lead to stagnation. AI doesn't do things the same way every single time but it also doesn't aim to "experiment" as a way to grow or to self-reflect on its own efficacy (which could lead to model collapse). That's almost at the level of sentience.
That’s a different thing indeed. In your case the AI
goes wild, will strip dance and tell poor jokes (while flirting with the ventilation machine)
I want that thing where a light "paints" over wounds and they heal.
Fringe cases yes, like rare conditions. It almost certainly won't be able to handle something completely unexpected.
The AI will (probably) be familiar with every possible issue that no human will be able to match.
I'm not sure what kind of "completely unexpected" situation is possible can happen, that a normal surgeon would handle better?
But I agree it would have to be a lot smarter than current LLM and self driving for instance. Like a whole other level of smarter. But I think that is where we are heading. -
But I agree it would have to be a lot smarter than current LLM and self driving for instance. Like a whole other level of smarter. But I think that is where we are heading.Would it be able to handle a sudden power outage? A fire alarm going off?
Naturally as this kind of thing moves into use on actual people it will be used on the wealthiest and most connected among us in equal measure to us lowly plebs right.....right?
Or more likely they weren't actually being lazy, they knew they needed to leave room for swelling and healing. The surgeons that did tight stitches thought theirs was better because it looked better immediately after the surgery.
Surgeons are actually pretty well known for being arrogant, and claiming anyone who doesn't do their neat and tight stitching is lazy is completely on brand for people like that.
Are you kidding!? It'll be rolled out to poor people first! (gotta iron out the last of the bugs somehow)
I'd bet on at least twenty years before it's in general use, since this is a radical change and it makes sense to be cautious about new technology in medicine. Initial clinical trials for some common, simple surgeries within ten years, though.
Hopefully more people learn that this is the important part.
It becomes nonsense when you just feed it everything and the kitchen sink. A well trained model works.
What happens to an ecmo machine during a power outage or fire alarm?
The idea should be to augment healthcare professionals with tools they can use. The hospital will need to have contingencies in place. I agree if that your point is that we can’t replace people with machines. But we can increase effectiveness with them.
So are we fully abandoning reason based robots?
Is the future gonna just be things that guess but just keep getting better at guessing?
I’m disappointed in the future.
without human help
That’s all people are too, though.
without human help
They should have specified "without physical human help."
