  • I just got a Chevy Volt and when I let up off the accelerator it will start the regen and significantly decrease my speed. I assume that my brake lights are coming on because so far no one has rear-ended me or yelled at me for not having brake lights. I wish there was a good way to tell for sure though. I think it's Hyundai that does not engage the brake lights for situations like this, as I've about hit one before.
    I don't think they illuminate the brake lights, hence my comment. Technology connections has talked about this, although IDK which video it was.
  • Brake light activates before the brakes engages, so they could just be resting their foot on the brake while coasting. Pretty normal defensive driving technique. People tend to do it in heavier traffic or when people are tailgating them. Gives a way faster brake response.
  • Couldn't we just use the point system from 5th element? The car noticed you did something illegal and dedicated from your point pool.
  • Risk Compension predicts that drivers would simply use this new information to drive more aggressively, negating any possible safety benefits.
    The classic example we already have of this is when you are stopped at a side road about to enter the main road, and a car coming towards you on the main road signals to turn in.
    Many people take the fact the other car has their turn signal on as a guarantee that it's safe to emerge, but any good driving instructor will tell you to wait until the car actually begins to turn before you yourself emerge.
    They had their signal on but that doesn't mean they're actually going to DO what the signal said they would.
    Same with the front brake light. It would be like "Well their front brake light came on, so I assumed it was safe to step into the crosswalk" NO. They could have just tapped the brake a second, doesn't mean they saw you, or they will actually stop.
  • For normal people, yes. This is to prevent accidents.
    Again, if you're too stupid to make sure the multiton hunk of metal is coming to a stop by all the other obvious visual markers, including watching it's speed compared to stationary objects like signs and lamp posts, then this won't do shit. People need more aweness of their surroundings, not a bunch of lights and horns because people won't pay attention.
    You enter the road when it's safe, not jump in and play frogger with lights hoping to get across.
  • I still think rear signaling could be improved dramatically by using a wide third-brake light to show the intensity of braking.
    Edit for consistency
  • This is stupid
  • It is to colorblind people. You could use something else of course, just saying...
    It's doesn't matter, since the absence or presence of light would still be perceived by colour blind people. It doesn't change how they would drive, as they are already driving with the knowledge of colour blindness in mind when looking at tail lights.
  • Theres a saying in computer stuff that applies nicely here. PEBKAC, problem exists between keyboard and computer...turn signals have to be turned on, no amount of engineering can fix bad driving.
  • it's forbidden to use rear fog lights under rain (it's more confusing than helpful)
    if you live somewhere dry, that's not a concern. But here it rains 1 day in 3
  • It's doesn't matter, since the absence or presence of light would still be perceived by colour blind people. It doesn't change how they would drive, as they are already driving with the knowledge of colour blindness in mind when looking at tail lights.
    Tail lights being red is fine if you live with the most common forms of colorblindness which fall into what we call “red-green colorblind.” It is still a different color than headlights.
    Now put those same red-green lights on the front, and we have a problem.
  • By signaling to oncoming traffic and vehicles approaching from the side, a front brake light provides an essential visual cue that a car is slowing down or preparing to stop. When the light is extinguished, it indicates that a stationary vehicle might initiate movement. According to Tomasch, this visual feedback can significantly truncate the reaction time for other road users, leading to shorter stopping distances and consequently diminishing the likelihood of accidents.
    Sounds reasonable. Personally I just want front turn signals to be visible from the opposite side again.
    So it sounds like you're checking to see when the light turns off, to know that the car is going.
    Sounds like what we actually need is a green accelerator light on the front of the car.
  • Japan introduced brake lights that increase intensity based on how hard the driver was braking. 20+ years ago. They tested it in the US and drivers found it to be “confusing.”
  • Not selling tanks as cars could also help. Especially with fatality rates
    But why? Again, the perception would be absence or presence of light on a standardized indicator.
    FYI signal lights are much more strictly regulated in Europe, such as position, colour, shape and strength.
    This study is from Austria.
    They could use traffic light green. There's not any problems identifying those even in places with the lights mounted horizontally. There's enough difference in saturation you can tell the difference even with colorblindness.
  • Here's an idea. How about we zap the drivers after they make a turn if they didn't use a turn signal beforehand? 😀
    Cars with lane-keep assist with vibrate the steering wheel and beep at you. It's at least something but I think most people turn it off if it gets annoying
  • Amazon is reportedly training humanoid robots to deliver packages
    298 Stimmen
    142 Beiträge
    Nice, thanks!
  • 324 Stimmen
    18 Beiträge
    1 Aufrufe
    D
    Do you think a plumber dreams about being a plumber?
  • Catbox.moe got screwed 😿
    55 Stimmen
    40 Beiträge
    2 Aufrufe
    archrecord@lemm.eeA
    I'll gladly give you a reason. I'm actually happy to articulate my stance on this, considering how much I tend to care about digital rights. Services that host files should not be held responsible for what users upload, unless: The service explicitly caters to illegal content by definition or practice (i.e. the if the website is literally titled uploadyourcsamhere[.]com then it's safe to assume they deliberately want to host illegal content) The service has a very easy mechanism to remove illegal content, either when asked, or through simple monitoring systems, but chooses not to do so (catbox does this, and quite quickly too) Because holding services responsible creates a whole host of negative effects. Here's some examples: Someone starts a CDN and some users upload CSAM. The creator of the CDN goes to jail now. Nobody ever wants to create a CDN because of the legal risk, and thus the only providers of CDNs become shady, expensive, anonymously-run services with no compliance mechanisms. You run a site that hosts images, and someone decides they want to harm you. They upload CSAM, then report the site to law enforcement. You go to jail. Anybody in the future who wants to run an image sharing site must now self-censor to try and not upset any human being that could be willing to harm them via their site. A social media site is hosting the posts and content of users. In order to be compliant and not go to jail, they must engage in extremely strict filtering, otherwise even one mistake could land them in jail. All users of the site are prohibited from posting any NSFW or even suggestive content, (including newsworthy media, such as an image of bodies in a warzone) and any violation leads to an instant ban, because any of those things could lead to a chance of actually illegal content being attached. This isn't just my opinion either. Digital rights organizations such as the Electronic Frontier Foundation have talked at length about similar policies before. To quote them: "When social media platforms adopt heavy-handed moderation policies, the unintended consequences can be hard to predict. For example, Twitter’s policies on sexual material have resulted in posts on sexual health and condoms being taken down. YouTube’s bans on violent content have resulted in journalism on the Syrian war being pulled from the site. It can be tempting to attempt to “fix” certain attitudes and behaviors online by placing increased restrictions on users’ speech, but in practice, web platforms have had more success at silencing innocent people than at making online communities healthier." Now, to address the rest of your comment, since I don't just want to focus on the beginning: I think you have to actively moderate what is uploaded Catbox does, and as previously mentioned, often at a much higher rate than other services, and at a comparable rate to many services that have millions, if not billions of dollars in annual profits that could otherwise be spent on further moderation. there has to be swifter and stricter punishment for those that do upload things that are against TOS and/or illegal. The problem isn't necessarily the speed at which people can be reported and punished, but rather that the internet is fundamentally harder to track people on than real life. It's easy for cops to sit around at a spot they know someone will be physically distributing illegal content at in real life, but digitally, even if you can see the feed of all the information passing through the service, a VPN or Tor connection will anonymize your IP address in a manner that most police departments won't be able to track, and most three-letter agencies will simply have a relatively low success rate with. There's no good solution to this problem of identifying perpetrators, which is why platforms often focus on moderation over legal enforcement actions against users so frequently. It accomplishes the goal of preventing and removing the content without having to, for example, require every single user of the internet to scan an ID (and also magically prevent people from just stealing other people's access tokens and impersonating their ID) I do agree, however, that we should probably provide larger amounts of funding, training, and resources, to divisions who's sole goal is to go after online distribution of various illegal content, primarily that which harms children, because it's certainly still an issue of there being too many reports to go through, even if many of them will still lead to dead ends. I hope that explains why making file hosting services liable for user uploaded content probably isn't the best strategy. I hate to see people with good intentions support ideas that sound good in practice, but in the end just cause more untold harms, and I hope you can understand why I believe this to be the case.
  • I am disappointed in the AI discourse
    8 Stimmen
    27 Beiträge
    2 Aufrufe
    artocode404@lemmy.dbzer0.comA
    I apologize that apparently Lemmy/Reddit people do not have enough self-awareness to accept good criticism, especially if it was just automatically generated and have downloaded that to oblivion. Though I don't really think you should respond to comments with a chatGPT link, not exactly helpful. Comes off a tad bit AI Bro...
  • 209 Stimmen
    30 Beiträge
    1 Aufrufe
    people do get desensitized down there from watching alot of porn, and there were other forums discussing thier "ED" from decade of porn watching.
  • UK government withholding details of Palantir contract
    15 Stimmen
    2 Aufrufe
    Of all the partners you could have picked. Eek.
  • 20 Stimmen
    Fantastic! Me and my 7 legs tank you so much!
  • 318 Stimmen
    45 Beiträge
    7 Aufrufe
    F
    By giving us the choice of whether someone else should profit by our data. Same as I don't want someone looking over my shoulder and copying off my test answers.
