337 165 9.7k
  • Microsoft breaks Windows reset and recovery
    414 Stimmen
    92 Beiträge
    55 Aufrufe
    N
    I use Linux Mint, which supports AppArmor or SELinux if you need the extra security, as well as allowing full disk encryption to be setup during install. Cinnamon (its default desktop environment) is very usable, especially if you’re used to Windows.
  • 354 Stimmen
    28 Beiträge
    103 Aufrufe
    gratux@lemmy.blahaj.zoneG
    Good luck detecting that with any kind of client-side anti-cheat. The game will now only play on a "secure" display, and the anti-cheat has privileges to monitor the entire chain from the GPU to the display. Non-conforming monitors or devices in the middle break the chain of trust and the game refuses to play. And then cheaters will shift to a camera pointed at the screen... Client-side anti cheat is an endless cat-and-mouse game.
  • 159 Stimmen
    18 Beiträge
    41 Aufrufe
    That's kind of my point. The bias is laid bare and I vious for those that listen. NPR did the very best at sharing information while fighting hard to stay neutral, AND kept listeners and viewers informed. They'll continue their mission, but many smaller affiliate stations that only have Sinclair media broadcasting in their neck of the woods are going to be moderately more screwed than they already were, with more conservative agitprop pretty much occupying their airwaves.
    12 Aufrufe
  • Nyamerican Jacket – Where Modern America Meets Timeless Fashion
    13 Aufrufe
  • 51 Stimmen
    97 Aufrufe
    B
    But do you also sometimes leave out AI for steps the AI often does for you, like the conceptualisation or the implementation? Would it be possible for you to do these steps as efficiently as before the use of AI? Would you be able to spot the mistakes the AI makes in these steps, even months or years along those lines? The main issue I have with AI being used in tasks is that it deprives you from using logic by applying it to real life scenarios, the thing we excel at. It would be better to use AI in the opposite direction you are currently use it as: develop methods to view the works critically. After all, if there is one thing a lot of people are bad at, it's thorough critical thinking. We just suck at knowing of all edge cases and how we test for them. Let the AI come up with unit tests, let it be the one that questions your work, in order to get a better perspective on it.
  • Electric Bikes
    20 Aufrufe
  • 311 Stimmen
    50 Beiträge
    731 Aufrufe
    The list of previous searches on his iPhone included “Which month is april in islam,” “Festivals happening near me,” “are suicide attacks haram in islam,” “ginger isis member,” “lone wolf terrorists isis,” and “can tou kill a woman who foesnt[sic] wear hijab.” lol of course he’s a fucking idiot
