Reading through the article, it seems like one scenario is that a vehicle stopped at an intersection might be about to pull out, endangering another vehicle about to cross? It seems like the thinking is, if you notice a front/side brake light stops being lit as you approach the intersection, it might indicate they're about to accelerate - be cautious!
I'm not fully convinced either, it seems like a lot of the benefit they're projecting is based on analysis of historical collisions, rather than any kind of experimental results. It sounds like the study is to justify expanding research to that sort of simulated experimentation, though - I'm curious what that kind of testing would find.
They also indicate slow moving road hazards like a semi carrying an oversized load
Faster blink is already used to indicate that one of the lights is burned out. It's a consequence of the mechanical part that operates (used to operate) the blinking; less resistance caused by a burned out light means it blinks faster
I'm pretty sure most cars have a turn signal near the headlights, and one on the mirror or on the side for that use case, no?
Actually I think I remember watching a technology connections video about how card in the US can use the headlights as a turn signal, or something like that.
I don't think that's allowed in Europe or the EU or whatever. -
with computers these days an acceleration based system should be achievable for all types of cars. hybrid/electric cars already do it with regen braking.
Not all of them. It is becoming more common, but for a while Hyundai and Kia didn't do this, and I know my older Ford doesn't.
Probably just in the US, since brake lights are only required when pressing the brake pedal. Mercedes illuminates them but then turns the brake lights off once the vehicle comes to a stop using regen.
I strongly doubt it was genuinely linked to that. There are EU countries where having lights on all the time is mandatory.
There was an EU rule about ten years ago that stipulated that rear lights are no longer mandatory in daylight. The reasoning being to save on fuel. Which is a ridiculous reason, even more so with today's LED lights.
All cars in Sweden used to have the rear lights turned on at all time, even if the light switch was in the off position, but that changed around the same time. -
https://www.youtube.com/watch?v=U0YW7x9U5TQ -
Yes that's all I want, to be able to see the indicator again. A lot of newer cars have moved them too far to the side of the vehicle.
I encounter this pretty often because a Boston area streets are terrible and the drivers are worse, so a visible indicator helps all drivers make traffic flow more smoothly.
Those are typically DRLs. Chrysler did this for a while in the 2000s-2010s (maybe still, idk), where the high beam - in DRL mode - turns off while the turn signal is doing it's thing. Other manufacturers do this with dedicated DRLs, sometimes integrating the DRLs and turn signals into one multicolored unit (Kia Telluride, for example).
No manufacturer shuts off a headlight for a turn signal when the headlights are intentionally turned on (whether by light sensors at night, or by the driver).
There are a couple situations where it's annoying and I turn it off. My truck has the "steer back into lane" style assist, but it's tried to push me off the road before while I was towing a trailer on some narrow 1-lane roads. Some of the corners it's just not possible to get around without touching the center line.
The vast majority of the time it stays on though and is quite helpful.
All cars in Sweden used to have the rear lights turned on at all time, even if the light switch was in the off position, but that changed around the same time.that stipulated that rear lights are no longer mandatory in daylight.
I don't believe these were ever mandatory in the EU? UK never had such requirement.
Edit:
What I mean is there are EU countries where lights are still mandatory and countries where it isn't so I cannot see how it could be linked to EU requirements either way.
I see a lot of those on trucks here in the south. Good for when you are towing shit so people can see around all your junk in the trailer.
Colorblind person here. If we're talking about limited visibility differentiation of front and back, the color of light is way less noticeable than whether we're looking at headlights or not (based on intensity). There would be no issue telling whether we're looking at a front brake light or a back brake light so long as the front brake light has headlights around it.
https://www.youtube.com/watch?v=U0YW7x9U5TQYeah my electric 208 is kinda like that (if I remember the video well, watched it a while ago) but since it's Europe there actually is a regulation about how much a car can decelerate before break lights come on, so instead of making the system turn the lights on they throttle how much it can decelerate for recharge and still makes you use the break to use full regen (and eventually the actual brakes, of course). So it's not a real "one pedal driving".
Edit for consistency
I think some cars also turn on the hazards automatically if you really hammer the breaks.
Okay Verstappen calm down there
There's this idea I've been considering for a long time.
Imagine putting a remote controlled firework smoke bomb under the tailpipe, hidden from sight. At best a really stinky one that smells like burned rubber or something.
When someone follows to closely, just fake an engine issue or something by activating the smoke bomb and fill their AC air intake with the smell of burned rubber for weeks. Just to teach them to not follow too closely again.
90% of the things that Japan introduced according to comment sections on the internet never happened (or never made it past the prototype stage) and the rest was actually introduced in Korea, not in Japan.
The Japanophilia is strong with a lot of people on the internet.
U.S. Senator Tom Cotton probes Intel board over CEO Lip-Bu Tan's former China links, raises national security concerns amid Cadence scandal
Mastercard and Visa face backlash after hundreds of adult games removed from online stores Steam and Itch.io
After an 11-month strike, Video game actors are voting on a new contract. Here’s what it means for AI in gaming
The codes require me to put \s in the start of a list after some items are typed whereas it works just fine before putting some items in list
Twenty-seven states and DC sue 23andMe to oppose the sale of DNA data from its customers without their direct consent
