Left to Right Programming
IMO all those examples are less readable than writing it in an imperative way using good function and variable names.
Also,
len()
is a Python convention and a built-in function that calls__len__()
on that object. It's even more established than.length
in JS, so I really don't see why someone would expect anything else. And even then, one could callmy_list.__len__()
if they really wanted to be sure and have that "left to right" bonus. -
That sounds a lot like Functional Programming
I also tend to prefer left to right and use threading macros a lot.
Except they don't like functional primitives like
map
unless they're namespaced to iterable types... -
I'm always suspicious of people who say that a language is suboptimal and use as evidence some filthy one-liner. Maybe if you bothered to write some whitespace and didn't write the language ignorant of its features (like generator expressions) you would end up with better code?
sum( all( abs(x) >= 1 and abs(x) <= 3 for x in line ) and ( all(x > 0 for x in line) or all(x < 0 for x in line) ) for line in diffs )
You no longer have to "jump back and forth" except one single time - you have to look to the end to see where
line
is coming from and then you can read the body of the main expression from start to finish.People don't, in fact, read code from top to bottom, left to right; they read it by first looking at its "skeleton" - functions, control flow, etc - until finding the bit they think is most important to read in detail. That implies that "jumping back and forth" is a natural and necessary part of reading (and hence writing) code, and so is nothing to fear.
There is still a slight advantage to not having to jump around, but consider the costs: in Javascript,
map
andfilter
are methods onArray
and some other types. So how are you going to implement them for your custom iterable type? Do you have to do it yourself, or write lots of boilerplate? It's easy in Python. It's not bad in Rust either because of traits, but what this all means is that to get this, you need other, heavy, language features.In practice, you often know what a comprehension is iterating over due to context. In those situations, having what the comprehension produces be the most prominent is actually a boon. In these scenarios in Rust/JS you are left skipping over the unimportant stuff to get to what you actually want to read.
line
map
andfilter
are methods onArray
I agree with you that the one liner isn't a good example, but I do prefer the "left to right" syntax shown in the article. My brain just really likes getting the information in this order: "Iterate over Collection, and for each object do Operation(object)".
The cost of writing member functions for each class is a valid concern. I'm really interested in the concept of uniform function call syntax for this reason, though I haven't played around with a language that has it to get a feeling of what its downsides might be.
I was also thinking about UFCS. I do like it for its flexibility, but I did try it in Nim one time and was left feeling unsure. Unfortunately I now can't remember what exactly I didn't like about it.
Is string length len, length, size, count, num, or # ? Is there even a global function for length? You won’t know until you try all of them.
This is Python basics, so the argument would be to optimize readability specifically for people who have zero familiarity with the language.
(The other examples have the same general direction of readability tradeoff to the benefit of beginners, this one was just simplest to pick here)
That's a valid tradeoff to discuss, if discussed as a tradeoff. Here it is not. The cost to readability for anyone with language familiarity appear to be not even understood.
The point of the article is about how IDE's can't validate certain things as you type them in this order. The example of a string length function could be replaced by any other API.
That is one of the points, yes.
But, the reason for wanting the IDE to validate based on partially entered expressions is given as making it easier to follow the code for a person working left-to-right.
And it's not an invalid thing to want, but I expect the discussion to also include how it affects reading the code for a non-beginner.
line
map
andfilter
are methods onArray
People don’t, in fact, read code from top to bottom, left to right
100% this.
This false premise is also why a few (objectively wrong) people defend writing long essays: functions with hundreds of lines and files with thousands; saying "then you don't have to go back and forth to read it", when in fact, no one should be reading it like a novel in the first place.
Once you get used with list and dict comprehensions, they read just fine. Much like the functional approach is not really that readable for a newcomer either.
I don't know about that,
len
is a built-in -- likestr
,abs
,bool
. There are only a few of them and they're well known by people familiar to the language (which seems to exclude the article author). Their use is more about the language itself than about what to expect from a particular API.In fact, most Python APIs that go beyond built-in usage actually look much more object-oriented with "left-to-right"
object.method()
calls. So this argument seems silly and goes away with some familiarity with that language. -
Comprehension is functional programming too, they arise from list monad https://www.schoolofhaskell.com/school/starting-with-haskell/basics-of-haskell/13-the-list-monad
And Haskell do notation indeed reads top-down, unlike Python, but I find both quite readable. -
It's got nothing to do with being a beginner. I've been working as a professional software developer for ~15 years now and still I have to use new libraries/frameworks/in-house dependencies quite frequently. I know how to get the length of a string, and so does the author of the article.
But that's why it's a simple example and nothing more, and it applies to everything else. We write left to right, and IDEs autocomplete left to right, so it makes sense for languages to be designed to work that way.
There's a lot of reasons why Java works much better with IDEs than python, and this is one of them.
Besides that, it is best practice to show problems on simple, easy to follow use cases that highlight exactly the problem in question without further fluff. It's expected that a non-beginner can abstract that problem into more difficult use cases, so I don't think OOP did anything wrong with choosing string length as an example.
len
,abs
,bool
object.method()
calls. So this argument seems silly and goes away with some familiarity with that language.The argument is not silly, it totally makes sense, and your point even proves that.
A lot of libraries use module-level globals and if you use from imports (especially
from X import *
) you get exactly that issue.Yes, many more modern APIs use an object-oriented approach, which is left-to-right, and that's exactly what OOP is argueing for. If you notice, he didn't end the post with "Make good languages" but with "Make good APIs". He highlights a common problem using well-known examples and generalizes it to all APIs.
The auther knows full well that this blog post will not cause Python to drop the List comprehension syntax or built-in functions. What he's trying to do is to get people to not use non-LTR approaces when designing APIs. All the points he made are correct, and many are even more pressing in other languages.
For example, for a hobby project of mine I have to use C/C++ (microcontrollers). And this problem is huge in C libraries. Every function is just dumped into the global name space and there's no way to easily find the right function. Often I have to go to google and search for an external documentation or open up the header files of a project to find a function that does what I want, instead of being able to just follow the IDE autocomplete on an object.
And sure, if I know every library and framework I use inside out and memorized all functions, methods, objects, variables and fields, then it's easy, but unless you work 30 years in a bank where you maintain the same old cobol script for decades, that's not going to happen.
line
map
andfilter
are methods onArray
Did we read the same blog post?
Not a single time did OOP talk about readability. That was not a point at all, so I don't know why you are all about readability.
It was all about having a language that the IDE can help you write in because it knows what you are talking about from the beginning of the line.
The issue with the horrible one-liner (and with your nicely split-up version) is that the IDE has no idea what object you are talking about until the second-to-last non-whitespace character. The only thing it can autocomplete is "diffs". Up until you typed the word, it has no idea whether sum(), all(), abs(), <, >, or for-in actually exist for the data type you are using.
If you did the same in Java, you'd start with
diffs
and from then on the IDE knows what you are talking about, can help you with suggesting functions/methods, can highlight typos and so on.That was the whole point of the blog post.
100% this.
The blog post wasn't about reading, but about writing. And people usually do write top-to-bottom, left-to-right.
The whole point of the blog post was to write code that the IDE can help you with when writing. It didn't go into readability even once.
I'll agree that list comprehensions can be a bit annoying to write because your IDE can't help you until the basic loop is done, but you solve that by just doing
[thing for thing in things]
and then add whatever conditions and attr access/function calls you need. -
diffs
I dunno, did we?
I think rust's iterator chains are nice, and IDE auto-complete is part of that niceness. But comprehension expressions read very naturally to me, more so than iterator chains.
I mean, how many python programmers don't even type hint their code, and so won't get (accurate) auto-complete anyway? Auto-completion is nice but just not the be-all and end-all.
"Tea" app - user database leaked today (incl. drivers license & IDs). Daily reminder not to give your ID to online services [THEY DO NOT PROTECT YOUR INFORMATION]
China’s Next-Gen TV Anchors Hustle for Jobs AI Already Does: The rise of AI in broadcasting is pushing China’s top journalism schools to rethink what skills still set human anchors apart.
Microsoft exits Pakistan after 25 years (post by Jawwad Rehman, who established and led Microsoft’s Pakistan subsidiary)
AI learns math reasoning by playing Snake and Tetris-like games rather than using math datasets
[JS Required] The OpenAI Files Document Broken Promises, Safety Compromises, Conflicts of Interest, and Leadership Concerns
