Left to Right Programming
The blog post wasn't about reading, but about writing. And people usually do write top-to-bottom, left-to-right.
The whole point of the blog post was to write code that the IDE can help you with when writing. It didn't go into readability even once.
the last section before the conclusion only mentions readability
The argument is not silly, it totally makes sense, and your point even proves that.
A lot of libraries use module-level globals and if you use from imports (especially
from X import *
) you get exactly that issue.Yes, many more modern APIs use an object-oriented approach, which is left-to-right, and that's exactly what OOP is argueing for. If you notice, he didn't end the post with "Make good languages" but with "Make good APIs". He highlights a common problem using well-known examples and generalizes it to all APIs.
The auther knows full well that this blog post will not cause Python to drop the List comprehension syntax or built-in functions. What he's trying to do is to get people to not use non-LTR approaces when designing APIs. All the points he made are correct, and many are even more pressing in other languages.
For example, for a hobby project of mine I have to use C/C++ (microcontrollers). And this problem is huge in C libraries. Every function is just dumped into the global name space and there's no way to easily find the right function. Often I have to go to google and search for an external documentation or open up the header files of a project to find a function that does what I want, instead of being able to just follow the IDE autocomplete on an object.
And sure, if I know every library and framework I use inside out and memorized all functions, methods, objects, variables and fields, then it's easy, but unless you work 30 years in a bank where you maintain the same old cobol script for decades, that's not going to happen.
from X import *
That's malpractice in most cases, and thankfully, becoming more rare to find in the wild. Any decent linter will shout at you for using star imports.
What he’s trying to do is to get people to not use non-LTR approaces when designing APIs.
Then he should have picked examples of APIs that break this, not use the built-in functions. Because as it reads now, it seems he is just against established conventions for purism.
yeah, one of my favorite things about python is that everything not in the language itself is either defined in the file, or explicitly imported. Unless, like mentioned, you have anti-patterns like star imports and scripts messing with globals().
I'm kinda surprised that pretty much nobody who commented here seems to have understood the point of the post.
It wasn't about readability at all.
It was about designing APIs that the IDE can help you with.
With RTL syntax the IDE doesn't know what you are talking about until the end of the line because the most important thing, the root object, the main context comes last. So you write your full statement and the IDE has no idea what you are on about, until you end at the very end of your statement.
Take a procedural-style statement:
len(str(myvar))
When you type it out, the IDE has no idea what you want to do, so it begins suggesting everything in the global namespace starting with l, and when you finish writing
len(
, all it can do is point out a syntax error for the rest of the line. Rinse and repeat for str and myvar.Object-oriented, the IDE can help out much more:
myvar.tostring().length()
With each dot the IDE knows what possible methods you cound mean, the autocomplete is much more focussed and after each
there are no open syntax errors and the IDE can verify that what you did was correct. And it you have a typo or reference a non-existing method it can instantly show you that instead having to wait until the end of the whole thing. -
I dunno, did we?
I think rust's iterator chains are nice, and IDE auto-complete is part of that niceness. But comprehension expressions read very naturally to me, more so than iterator chains.
I mean, how many python programmers don't even type hint their code, and so won't get (accurate) auto-complete anyway? Auto-completion is nice but just not the be-all and end-all.
Fair, I missed one word. You missed the whole blog post.
It's a big difference between writing code and writin APIs, tbh. If you write crap code that's your problem. If you write crap APIs it's the problem of anyone using your API.
What about all the other sections?
from X import *
He's using simple examples that everyone knows and understands instantly. It's like using a minimal test case to report a bug. In most cases a minimal test case is also nonsensical on its own, but it's used to show an issue that occurred in a more complex context without overloading the reader with useless garbage info that doesn't contribute to the point at hand.
The blog post is really about language design, because you definitely should not write a
filter
method for your custom iterable class in python; you should make it use the language's interface's for "being an iterable". Language design involves APIs offered by the language, but isn't really the purview of most people who write APIs.If a suggestion on language design would gain something at the cost of readability, anyone should be very skeptical of that.
Those things together explain why I am evaluating the post mostly in terms of readability.
I agree with you that the one liner isn't a good example, but I do prefer the "left to right" syntax shown in the article. My brain just really likes getting the information in this order: "Iterate over Collection, and for each object do Operation(object)".
The cost of writing member functions for each class is a valid concern. I'm really interested in the concept of uniform function call syntax for this reason, though I haven't played around with a language that has it to get a feeling of what its downsides might be.
I think Nim is the frontrunner here. Close to Python to write because it is so expressive, close to C speed because it is compiled properly.
Did we read the same blog post?
Not a single time did OOP talk about readability. That was not a point at all, so I don't know why you are all about readability.
It was all about having a language that the IDE can help you write in because it knows what you are talking about from the beginning of the line.
The issue with the horrible one-liner (and with your nicely split-up version) is that the IDE has no idea what object you are talking about until the second-to-last non-whitespace character. The only thing it can autocomplete is "diffs". Up until you typed the word, it has no idea whether sum(), all(), abs(), <, >, or for-in actually exist for the data type you are using.
If you did the same in Java, you'd start with
diffs
and from then on the IDE knows what you are talking about, can help you with suggesting functions/methods, can highlight typos and so on.That was the whole point of the blog post.
Yep, and my takeaway from it is "don't distort your syntax in order to allow yourself to be more dependent on an IDE."
Luddite take.
Trump shooting and Biden exit flipped social media from hostility to solidarity: how political crises cause a shift in the force behind viral online content ‘from outgroup hate to ingroup love’.
Cloudflare gets involved in the battle against piracy, blocking streaming websites in the UK — and VPNs won't help
