Left to Right Programming
Is string length len, length, size, count, num, or # ? Is there even a global function for length? You won’t know until you try all of them.
This is Python basics, so the argument would be to optimize readability specifically for people who have zero familiarity with the language.
(The other examples have the same general direction of readability tradeoff to the benefit of beginners, this one was just simplest to pick here)
That's a valid tradeoff to discuss, if discussed as a tradeoff. Here it is not. The cost to readability for anyone with language familiarity appear to be not even understood.
The point of the article is about how IDE's can't validate certain things as you type them in this order. The example of a string length function could be replaced by any other API.
That is one of the points, yes.
But, the reason for wanting the IDE to validate based on partially entered expressions is given as making it easier to follow the code for a person working left-to-right.
And it's not an invalid thing to want, but I expect the discussion to also include how it affects reading the code for a non-beginner.
I'm always suspicious of people who say that a language is suboptimal and use as evidence some filthy one-liner. Maybe if you bothered to write some whitespace and didn't write the language ignorant of its features (like generator expressions) you would end up with better code?
sum( all( abs(x) >= 1 and abs(x) <= 3 for x in line ) and ( all(x > 0 for x in line) or all(x < 0 for x in line) ) for line in diffs )
You no longer have to "jump back and forth" except one single time - you have to look to the end to see where
line
is coming from and then you can read the body of the main expression from start to finish.People don't, in fact, read code from top to bottom, left to right; they read it by first looking at its "skeleton" - functions, control flow, etc - until finding the bit they think is most important to read in detail. That implies that "jumping back and forth" is a natural and necessary part of reading (and hence writing) code, and so is nothing to fear.
There is still a slight advantage to not having to jump around, but consider the costs: in Javascript,
map
andfilter
are methods onArray
and some other types. So how are you going to implement them for your custom iterable type? Do you have to do it yourself, or write lots of boilerplate? It's easy in Python. It's not bad in Rust either because of traits, but what this all means is that to get this, you need other, heavy, language features.In practice, you often know what a comprehension is iterating over due to context. In those situations, having what the comprehension produces be the most prominent is actually a boon. In these scenarios in Rust/JS you are left skipping over the unimportant stuff to get to what you actually want to read.
People don’t, in fact, read code from top to bottom, left to right
100% this.
This false premise is also why a few (objectively wrong) people defend writing long essays: functions with hundreds of lines and files with thousands; saying "then you don't have to go back and forth to read it", when in fact, no one should be reading it like a novel in the first place.
Once you get used with list and dict comprehensions, they read just fine. Much like the functional approach is not really that readable for a newcomer either.
I don't know about that,
len
is a built-in -- likestr
,abs
,bool
. There are only a few of them and they're well known by people familiar to the language (which seems to exclude the article author). Their use is more about the language itself than about what to expect from a particular API.In fact, most Python APIs that go beyond built-in usage actually look much more object-oriented with "left-to-right"
object.method()
calls. So this argument seems silly and goes away with some familiarity with that language. -
That sounds a lot like Functional Programming
Comprehension is functional programming too, they arise from list monad https://www.schoolofhaskell.com/school/starting-with-haskell/basics-of-haskell/13-the-list-monad
And Haskell do notation indeed reads top-down, unlike Python, but I find both quite readable. -
It's got nothing to do with being a beginner. I've been working as a professional software developer for ~15 years now and still I have to use new libraries/frameworks/in-house dependencies quite frequently. I know how to get the length of a string, and so does the author of the article.
But that's why it's a simple example and nothing more, and it applies to everything else. We write left to right, and IDEs autocomplete left to right, so it makes sense for languages to be designed to work that way.
There's a lot of reasons why Java works much better with IDEs than python, and this is one of them.
Besides that, it is best practice to show problems on simple, easy to follow use cases that highlight exactly the problem in question without further fluff. It's expected that a non-beginner can abstract that problem into more difficult use cases, so I don't think OOP did anything wrong with choosing string length as an example.
len
,abs
,bool
object.method()
calls. So this argument seems silly and goes away with some familiarity with that language.The argument is not silly, it totally makes sense, and your point even proves that.
A lot of libraries use module-level globals and if you use from imports (especially
from X import *
) you get exactly that issue.Yes, many more modern APIs use an object-oriented approach, which is left-to-right, and that's exactly what OOP is argueing for. If you notice, he didn't end the post with "Make good languages" but with "Make good APIs". He highlights a common problem using well-known examples and generalizes it to all APIs.
The auther knows full well that this blog post will not cause Python to drop the List comprehension syntax or built-in functions. What he's trying to do is to get people to not use non-LTR approaces when designing APIs. All the points he made are correct, and many are even more pressing in other languages.
For example, for a hobby project of mine I have to use C/C++ (microcontrollers). And this problem is huge in C libraries. Every function is just dumped into the global name space and there's no way to easily find the right function. Often I have to go to google and search for an external documentation or open up the header files of a project to find a function that does what I want, instead of being able to just follow the IDE autocomplete on an object.
And sure, if I know every library and framework I use inside out and memorized all functions, methods, objects, variables and fields, then it's easy, but unless you work 30 years in a bank where you maintain the same old cobol script for decades, that's not going to happen.
line
map
andfilter
are methods onArray
Did we read the same blog post?
Not a single time did OOP talk about readability. That was not a point at all, so I don't know why you are all about readability.
It was all about having a language that the IDE can help you write in because it knows what you are talking about from the beginning of the line.
The issue with the horrible one-liner (and with your nicely split-up version) is that the IDE has no idea what object you are talking about until the second-to-last non-whitespace character. The only thing it can autocomplete is "diffs". Up until you typed the word, it has no idea whether sum(), all(), abs(), <, >, or for-in actually exist for the data type you are using.
If you did the same in Java, you'd start with
diffs
and from then on the IDE knows what you are talking about, can help you with suggesting functions/methods, can highlight typos and so on.That was the whole point of the blog post.
100% this.
The blog post wasn't about reading, but about writing. And people usually do write top-to-bottom, left-to-right.
The whole point of the blog post was to write code that the IDE can help you with when writing. It didn't go into readability even once.
I'll agree that list comprehensions can be a bit annoying to write because your IDE can't help you until the basic loop is done, but you solve that by just doing
[thing for thing in things]
and then add whatever conditions and attr access/function calls you need. -
diffs
I dunno, did we?
I think rust's iterator chains are nice, and IDE auto-complete is part of that niceness. But comprehension expressions read very naturally to me, more so than iterator chains.
I mean, how many python programmers don't even type hint their code, and so won't get (accurate) auto-complete anyway? Auto-completion is nice but just not the be-all and end-all.
the last section before the conclusion only mentions readability
from X import *
from X import *
That's malpractice in most cases, and thankfully, becoming more rare to find in the wild. Any decent linter will shout at you for using star imports.
What he’s trying to do is to get people to not use non-LTR approaces when designing APIs.
Then he should have picked examples of APIs that break this, not use the built-in functions. Because as it reads now, it seems he is just against established conventions for purism.
yeah, one of my favorite things about python is that everything not in the language itself is either defined in the file, or explicitly imported. Unless, like mentioned, you have anti-patterns like star imports and scripts messing with globals().
I'm kinda surprised that pretty much nobody who commented here seems to have understood the point of the post.
It wasn't about readability at all.
It was about designing APIs that the IDE can help you with.
With RTL syntax the IDE doesn't know what you are talking about until the end of the line because the most important thing, the root object, the main context comes last. So you write your full statement and the IDE has no idea what you are on about, until you end at the very end of your statement.
Take a procedural-style statement:
len(str(myvar))
When you type it out, the IDE has no idea what you want to do, so it begins suggesting everything in the global namespace starting with l, and when you finish writing
len(
, all it can do is point out a syntax error for the rest of the line. Rinse and repeat for str and myvar.Object-oriented, the IDE can help out much more:
myvar.tostring().length()
With each dot the IDE knows what possible methods you cound mean, the autocomplete is much more focussed and after each
there are no open syntax errors and the IDE can verify that what you did was correct. And it you have a typo or reference a non-existing method it can instantly show you that instead having to wait until the end of the whole thing. -
I dunno, did we?
Fair, I missed one word. You missed the whole blog post.
It's a big difference between writing code and writin APIs, tbh. If you write crap code that's your problem. If you write crap APIs it's the problem of anyone using your API.
What about all the other sections?
from X import *
He's using simple examples that everyone knows and understands instantly. It's like using a minimal test case to report a bug. In most cases a minimal test case is also nonsensical on its own, but it's used to show an issue that occurred in a more complex context without overloading the reader with useless garbage info that doesn't contribute to the point at hand.
The blog post is really about language design, because you definitely should not write a
filter
method for your custom iterable class in python; you should make it use the language's interface's for "being an iterable". Language design involves APIs offered by the language, but isn't really the purview of most people who write APIs.If a suggestion on language design would gain something at the cost of readability, anyone should be very skeptical of that.
Those things together explain why I am evaluating the post mostly in terms of readability.
Texas Attorney General Ken Paxton Investigates Meta and Character.AI for Misleading Children with Deceptive AI-Generated Mental Health Services
YouTube relaxes moderation rules to allow more controversial content. Videos are allowed if "freedom of expression value may outweigh harm risk"
Prototype of RTX 5090 Appears With Four 16-Pin Power Connectors, Capable of Delivering 2,400W
