It's got to be a lie
1,000 charge cycles: OnePlus 13
Hmm. This one has newer silicone-carbon lithium-ion batteries, which should actually increase charge cycles, so what's happening here?
Isn't one plus one of the brands that has their own fast charging tech, that's extra fast?
Xiaomi has faast charge, and it (33watt) has worked both fast and reliable on my 4-5 year old note 9 pro phone. I just changed to a 13tp with 120 watt, let's see how that pans out
Yes, but...
edit: clarity
Apparently not
Yes, but...
edit: clarity
Nvidia's latest DLSS revision reduces VRAM usage by 20% for upscaling — optimizations reduce overhead of more powerful transformer model
The $10 billion delivery empire built on Shein and TikTok orders: A Chinese courier company is out-delivering Amazon — and everyone else — across Southeast Asia.
Chinese AI outfits smuggling suitcases full of hard drives to evade U.S. chip restrictions — training AI models in Malaysia using rented servers
