It's got to be a lie
1,000 charge cycles: OnePlus 13
Hmm. This one has newer silicone-carbon lithium-ion batteries, which should actually increase charge cycles, so what's happening here?
Isn't one plus one of the brands that has their own fast charging tech, that's extra fast?
Xiaomi has faast charge, and it (33watt) has worked both fast and reliable on my 4-5 year old note 9 pro phone. I just changed to a 13tp with 120 watt, let's see how that pans out
Yes, but...
edit: clarity
Apparently not
Yes, but...
edit: clarity
China New Internet ID System a Threat to Online Expression: Netizens will require IDs to go on the internet. For now this is voluntary, but there are signs it will not remain that way for long.
Airbnb’s Dying Software Gets a Second Life: The AI boom has revitalized a stagnant open-source project
