around 38C
around 38C
It's rare for me to get that low, even while charging to 80%.
I do like the trend chart, although, the battery health on that actually went UP 5% between March and May
I don't see that menu option. I do see Settings -> Battery but it does not count cycles.
Pixel 4a Android 14
Article 5
Article 6
They also say this:
So I remain hopeful.
I'm on pixel 6a. There is no battery info there
Although, replacing the battery on the Fairphone is so much easier that 1000 cycles is acceptable.
