  • And my feeling is that they aren’t using the gains from this to make the batteries last, as SUPERVOOC is faster than pretty much every other standard. That makes me think they turned in any and all gains in battery health, for speed.
    around 38C
  • Awesome! Good to know its based off some kind of standardized testing. This is good for everyone!
  • around 38C
    It's rare for me to get that low, even while charging to 80%. 😵
    I do like the trend chart, although, the battery health on that actually went UP 5% between March and May 😱
  • I don't see that menu option. I do see Settings -> Battery but it does not count cycles.
    Pixel 4a Android 14
  • the actual legislation is not that specific as far as i can tell:
    Article 5
    Article 6
    They also say this:
    So I remain hopeful.
  • I had the same phone, and the only reason I replaced it was because the USB C port was finicky. It must have been damaged at some point and when plugged in, the cable had to be just right. Wireless charging works great, but I wanted the stability of being able to plug in and know it would discharge over night when I didn't have a wireless charger. Otherwise, I had no issues with the battery, and I got the phone when it was pretty new to the market. I swapped it out just a few months back, and it's going to be my test phone for grapheneOS and may end up being a communal remote.
