Article 5
Article 6
Where can you see charge cycles?
Yeah I've got a P7 Pro and the battery is still fine. Adaptive charging enabled to help batter life.
around 38C
around 38C
It's rare for me to get that low, even while charging to 80%.
I do like the trend chart, although, the battery health on that actually went UP 5% between March and May
I don't see that menu option. I do see Settings -> Battery but it does not count cycles.
Pixel 4a Android 14
Article 5
Article 6
They also say this:
So I remain hopeful.
I'm on pixel 6a. There is no battery info there
Although, replacing the battery on the Fairphone is so much easier that 1000 cycles is acceptable.
Damn, yeah. My pixel will drain 50% or more in a day, in my pocket. Brutal
Anthropic tested Claude's(LLM, AI Chatbot) ability to manage a physical “storefront” to mixed results, as the AI struggled with pricing strategy and inventory management
Microsoft’s vast advertising business is target of Irish Council for Civil Liberties (ICCL) Enforce application for class action launch under EU data law
We have reached the “severed fingers and abductions” stage of the crypto revolution - Ars Technica
