Article 5
Article 6
Where can you see charge cycles?
Yeah I've got a P7 Pro and the battery is still fine. Adaptive charging enabled to help batter life.
around 38C
around 38C
It's rare for me to get that low, even while charging to 80%.
I do like the trend chart, although, the battery health on that actually went UP 5% between March and May
eSafety boss wants YouTube included in the social media ban. But AI raises even more concerns for kids
Republican National Convention Sued for Sending Unhinged Text Messages Soliciting Donations to Donald Trump’s Campaign and Continuing to Text Even After Trying to Unsubscribe.
Russia's State Duma passes bill to create state messaging app as it considers blocking WhatsApp
