  • Is piefed an instance?
  • How so?
  • Apparently not
    Article 5
    Article 6
    Article 5
    Article 6
  • And my feeling is that they aren’t using the gains from this to make the batteries last, as SUPERVOOC is faster than pretty much every other standard. That makes me think they turned in any and all gains in battery health, for speed.
    around 38C
  • Awesome! Good to know its based off some kind of standardized testing. This is good for everyone!
  • around 38C
    It's rare for me to get that low, even while charging to 80%. 😵
    I do like the trend chart, although, the battery health on that actually went UP 5% between March and May 😱
