    Is piefed an instance?
  • Is piefed an instance?
  • How so?
  • Apparently not
    Article 5
    Article 6
    Article 5
    Article 6
  • And my feeling is that they aren’t using the gains from this to make the batteries last, as SUPERVOOC is faster than pretty much every other standard. That makes me think they turned in any and all gains in battery health, for speed.
    around 38C
  • Awesome! Good to know its based off some kind of standardized testing. This is good for everyone!
  • around 38C
    It's rare for me to get that low, even while charging to 80%. 😵
    I do like the trend chart, although, the battery health on that actually went UP 5% between March and May 😱
  • Sierpinski triangle programs by 5 AI models
    15 Stimmen
    20 Aufrufe
    oh, wow! that's so cool!
  • Was ist ChatGPT?
    10 Aufrufe
  • The British jet engine that failed in the 'Valley of Death'
    40 Stimmen
    16 Beiträge
    33 Aufrufe
    R
    Giving up advancements in science and technology is stagnation. That's not what I'm suggesting. I'm suggesting giving up some particular, potential advancements in science and tecnology, which is a whole different kettle of fish and does not imply stagnation. Thinking it’s a good idea to not do anything until people are fed and housed is stagnation. Why do you think that?
  • 502 Stimmen
    133 Beiträge
    85 Aufrufe
    J
    Headlines have length constraints
  • Covert Web-to-App Tracking via Localhost on Android
    42 Stimmen
    13 Aufrufe
    Thanks for sharing this, it is an interesting read (though an additional comment about what this about would have been helpful). I want to say I am glad I do not use either of these services but Yandex implementation seems so bad that it does not matter, as any app could receive their data
  • 186 Stimmen
    18 Beiträge
    20 Aufrufe
    N
    Part of the reason for my use of "might".
  • 462 Stimmen
    94 Beiträge
    56 Aufrufe
    Make them publishers or whatever is required to have it be a legal requirement, have them ban people who share false information. The law doesn't magically make open discussions not open. By design, social media is open. If discussion from the public is closed, then it's no longer social media. ban people who share false information Banning people doesn't stop falsehoods. It's a broken solution promoting a false assurance. Authorities are still fallible & risk banning over unpopular/debatable expressions that may turn out true. There was unpopular dissent over covid lockdown policies in the US despite some dramatic differences with EU policies. Pro-palestinian protests get cracked down. Authorities are vulnerable to biases & swayed. Moreover, when people can just share their falsehoods offline, attempting to ban them online is hard to justify. If print media, through its decline, is being held legally responsible Print media is a controlled medium that controls it writers & approves everything before printing. It has a prepared, coordinated message. They can & do print books full of falsehoods if they want. Social media is open communication where anyone in the entire public can freely post anything before it is revoked. They aren't claiming to spread the truth, merely to enable communication.
  • 168 Stimmen
    11 Beiträge
    25 Aufrufe
    Law enforcement officer
