  • How so?
    Is piefed an instance?
  • Is piefed an instance?
  • How so?
  • Apparently not
    Article 5
    Article 6
    Article 5
    Article 6
  • 62 Stimmen
    16 Beiträge
    Anything else would be in flagrant violation of the GDPR (and this too, probably, though not as flagrantly).
  • 67 Stimmen
    2 Aufrufe
  • www2025
    4 Aufrufe
  • 84 Stimmen
    13 Beiträge
    23 Aufrufe
    It's a bit of a sticking point in Australia which is becoming more and more of a 'two-speed' society. Foxtel is for the rich classes, it caters to the right wing. Sky News is on Foxtel. These eSafety directives killing access to youtube won't affect those rich kids so much, but for everyone else it's going to be a nightmare. My only possible hope out of this is that maybe, Parliament and ACMA (Australian Communications and Media Authority, TV standards) decide that since we need a greater media landscape for kids and they can't be allowed to have it online, that maybe more than 3 major broadcasters could be allowed. It's not a lack of will that stops anyone else making a new free-to-air network, it's legislation, there are only allowed to be 3 commercial FTA broadcasters in any area. I don't love Youtube or the kids watching it, it's that the alternatives are almost objectively worse. 10 and 7 and garbage 24/7 and 9 is basically a right-wing hugbox too.
  • Firefox 140 Brings Tab Unload, Custom Search & New ESR
    234 Stimmen
    41 Beiträge
    64 Aufrufe
    Read again. I quoted something along the lines of "just as much a development decision as a marketing one" and I said, it wasn't a development decision, so what's left? Firefox released just as frequently before, just that they didn’t increase the major version that often. This does not appear to be true. Why don't you take a look at the version history instead of some marketing blog post? https://www.mozilla.org/en-US/firefox/releases/ Version 2 had 20 releases within 730 days, averaging one release every 36.5 days. Version 3 had 19 releases within 622 days, averaging 32.7 days per release. But these releases were unscheduled, so they were released when they were done. Now they are on a fixed 90-day schedule, no matter if anything worthwhile was complete or not, plus hotfix releases whenever they are necessary. That's not faster, but instead scheduled, and also they are incrementing the major version even if no major change was included. That's what the blog post was alluding to. In the before times, a major version number increase indicated major changes. Now it doesn't anymore, which means sysadmins still need to consider each release a major release, even if it doesn't contain major changes because it might contain them and the version name doesn't say anything about whether it does or not. It's nothing but a marketing change, moving from "version numbering means something" to "big number go up".
  • Catbox.moe got screwed 😿
    55 Stimmen
    40 Beiträge
    44 Aufrufe
    archrecord@lemm.eeA
    I'll gladly give you a reason. I'm actually happy to articulate my stance on this, considering how much I tend to care about digital rights. Services that host files should not be held responsible for what users upload, unless: The service explicitly caters to illegal content by definition or practice (i.e. the if the website is literally titled uploadyourcsamhere[.]com then it's safe to assume they deliberately want to host illegal content) The service has a very easy mechanism to remove illegal content, either when asked, or through simple monitoring systems, but chooses not to do so (catbox does this, and quite quickly too) Because holding services responsible creates a whole host of negative effects. Here's some examples: Someone starts a CDN and some users upload CSAM. The creator of the CDN goes to jail now. Nobody ever wants to create a CDN because of the legal risk, and thus the only providers of CDNs become shady, expensive, anonymously-run services with no compliance mechanisms. You run a site that hosts images, and someone decides they want to harm you. They upload CSAM, then report the site to law enforcement. You go to jail. Anybody in the future who wants to run an image sharing site must now self-censor to try and not upset any human being that could be willing to harm them via their site. A social media site is hosting the posts and content of users. In order to be compliant and not go to jail, they must engage in extremely strict filtering, otherwise even one mistake could land them in jail. All users of the site are prohibited from posting any NSFW or even suggestive content, (including newsworthy media, such as an image of bodies in a warzone) and any violation leads to an instant ban, because any of those things could lead to a chance of actually illegal content being attached. This isn't just my opinion either. Digital rights organizations such as the Electronic Frontier Foundation have talked at length about similar policies before. To quote them: "When social media platforms adopt heavy-handed moderation policies, the unintended consequences can be hard to predict. For example, Twitter’s policies on sexual material have resulted in posts on sexual health and condoms being taken down. YouTube’s bans on violent content have resulted in journalism on the Syrian war being pulled from the site. It can be tempting to attempt to “fix” certain attitudes and behaviors online by placing increased restrictions on users’ speech, but in practice, web platforms have had more success at silencing innocent people than at making online communities healthier." Now, to address the rest of your comment, since I don't just want to focus on the beginning: I think you have to actively moderate what is uploaded Catbox does, and as previously mentioned, often at a much higher rate than other services, and at a comparable rate to many services that have millions, if not billions of dollars in annual profits that could otherwise be spent on further moderation. there has to be swifter and stricter punishment for those that do upload things that are against TOS and/or illegal. The problem isn't necessarily the speed at which people can be reported and punished, but rather that the internet is fundamentally harder to track people on than real life. It's easy for cops to sit around at a spot they know someone will be physically distributing illegal content at in real life, but digitally, even if you can see the feed of all the information passing through the service, a VPN or Tor connection will anonymize your IP address in a manner that most police departments won't be able to track, and most three-letter agencies will simply have a relatively low success rate with. There's no good solution to this problem of identifying perpetrators, which is why platforms often focus on moderation over legal enforcement actions against users so frequently. It accomplishes the goal of preventing and removing the content without having to, for example, require every single user of the internet to scan an ID (and also magically prevent people from just stealing other people's access tokens and impersonating their ID) I do agree, however, that we should probably provide larger amounts of funding, training, and resources, to divisions who's sole goal is to go after online distribution of various illegal content, primarily that which harms children, because it's certainly still an issue of there being too many reports to go through, even if many of them will still lead to dead ends. I hope that explains why making file hosting services liable for user uploaded content probably isn't the best strategy. I hate to see people with good intentions support ideas that sound good in practice, but in the end just cause more untold harms, and I hope you can understand why I believe this to be the case.
  • Apple Reportedly Weighs iPhone Price Increase
    21 Stimmen
    13 Aufrufe
    Anytime I consider making the jump, I make my peace with everything and then the price hits...no way
  • 24 Stimmen
    7 Aufrufe
    toastedravioli@midwest.socialT
    Im all for making the traditional market more efficient and transparent, if blockchain can accommodate that, so long as we can also make crypto more like the traditional market. At least in terms of criminalizing shit that would obviously be illegal to do with securities
