OnePlus offloads heat to the charger
With heavy usage all my Samsung phones barely made it through a full day. I've never considered throttling the battery for the sake of longevity or been encouraged to by my phones. -
With heavy usage all my Samsung phones barely made it through a full day. I've never considered throttling the battery for the sake of longevity or been encouraged to by my phones.When you do the initial setup it asks if you'd like to optimize for battery health and most people say yes. Most recently it wouldn't even tell you that it was only charging to 80%.It would still charge to a hundred but that would actually be eighty percent. Around a year ago they changed it so now it says eighty percent when you're at full charge if you have the battery health turned on.
Is piefed an instance?
With heavy usage all my Samsung phones barely made it through a full day. I've never considered throttling the battery for the sake of longevity or been encouraged to by my phones.It's all up to where you live and how you use the phone.
Apparently not
Article 5
Article 6
Article 5
Article 6
Where can you see charge cycles?
Yeah I've got a P7 Pro and the battery is still fine. Adaptive charging enabled to help batter life.
