  • Wow. This is excellent for Samsung users.
    Apparently not
    Yes, but...
    edit: clarity
  • How so?
    Is piefed an instance?
  • Is piefed an instance?
  • How so?
  • Apparently not
    Article 5
    Article 6
  • 76 Stimmen
    8 Aufrufe
    etherphon@lemmy.worldE
    We all know how well not regulating social media has gone, why the fuck not let's just double down.
  • How can websites verify unique (IRL) identities?
    8 Stimmen
    15 Aufrufe
    H
    Safe, yeah. Private, no. If you want to verify whether a user is a real person, you need very personally identifiable information. That’s not ever going to be private. The best you could do, in theory, is have a government service that takes that PII and gives the user a signed cryptographic certificate they can use to verify their identity. Most people would either lose their private key or have it stolen, so even that system would have problems. The closest to reality you could do right now is use Apple’s FaceID, and that’s anything but private. Pretty safe though. It’s super illegal and quite hard to steal someone’s face.
  • Honda successfully launched and landed its own reusable rocket
    1k Stimmen
    170 Beiträge
    69 Aufrufe
    gerryflap@feddit.nlG
    Call me an optimist, but I still hold the hope that we can one day do better as humanity than we do now. Humanity has become a "better" species throughout its existence overall. Even a hundred years ago we were much more horrible and brutal than we are now. The current trend is not great, with climate change and far-right grifters taking control. But I hold hope that in the end this is but a blip on the radar. Horrible for us now, but in the grand scheme of things not something that will end humanity. It might in the worst case set us back a few hundred years.
  • 35 Stimmen
    7 Aufrufe
  • Claude Exporter: Claude to PDF, MD and more
    8 Aufrufe
  • The FDA Is Approving Drugs Without Evidence They Work
    506 Stimmen
    69 Beiträge
    63 Aufrufe
    Now you hit me curious too. This was my source on Texas https://www.texasalmanac.com/place-types/town Also the total number of total towns is over 4,000 with only 3k unincorporated, I did get the numbers wrong even in Texas. I had looked at Wikipedia but could not find totals, only lists
  • 124 Stimmen
    12 Beiträge
    21 Aufrufe
    Premium supported. You get plenty with the free tier, but you get lots more with paid.
    5 Aufrufe
    Sure thing! So glad I could be helpful! I don't blame you. It's the only thing I'm keeping a Win10 dual-boot for right now, and to their credit, it does work quite well in Windows. We've had a ton of fun with our set. In the meantime, I'm keeping up with the project but not actively tinkering with it myself, because it's exciting but also not quite there yet. It's at least given me hope that it can be done though! I'm confident we'll see significant gains sooner rather than later. Hats off to them. (Once my income stabilizes I'll gotta pitch them some funds...) Envision has made it VERY convenient to get set up, but the whole process still saps more time than "Fire it up and play." So maybe play with it at some point, but either way definitely keep your ear to the ground. I'm hoping in the future we'll get to use it for things like Godot XR or Blender integration.
