  • Isn't one plus one of the brands that has their own fast charging tech, that's extra fast?
    Xiaomi has faast charge, and it (33watt) has worked both fast and reliable on my 4-5 year old note 9 pro phone. I just changed to a 13tp with 120 watt, let's see how that pans out 🔥😋
    Yes, but...
    edit: clarity
  • Wow. This is excellent for Samsung users.
    Apparently not
    Yes, but...
    edit: clarity
  • How so?
