1,000 charge cycles: OnePlus 13
Hmm. This one has newer silicone-carbon lithium-ion batteries, which should actually increase charge cycles, so what's happening here?
Isn't one plus one of the brands that has their own fast charging tech, that's extra fast?
Xiaomi has faast charge, and it (33watt) has worked both fast and reliable on my 4-5 year old note 9 pro phone. I just changed to a 13tp with 120 watt, let's see how that pans out
Yes, but...
edit: clarity
Apparently not
Yes, but...
edit: clarity
With heavy usage all my Samsung phones barely made it through a full day. I've never considered throttling the battery for the sake of longevity or been encouraged to by my phones. -
With heavy usage all my Samsung phones barely made it through a full day. I've never considered throttling the battery for the sake of longevity or been encouraged to by my phones.When you do the initial setup it asks if you'd like to optimize for battery health and most people say yes. Most recently it wouldn't even tell you that it was only charging to 80%.It would still charge to a hundred but that would actually be eighty percent. Around a year ago they changed it so now it says eighty percent when you're at full charge if you have the battery health turned on.
Bruce Lee, Jackie Chan and ‘A Better Tomorrow’: AI-Powered Kung Fu Film Plan Debuts in Shanghai
Google Play’s latest security change may break many Android apps for some power users. The Play Integrity API uses hardware-backed signals that are trickier for rooted devices and custom ROMs to pass.
