1,000 charge cycles: OnePlus 13
Hmm. This one has newer silicone-carbon lithium-ion batteries, which should actually increase charge cycles, so what's happening here?
Isn't one plus one of the brands that has their own fast charging tech, that's extra fast?
Xiaomi has faast charge, and it (33watt) has worked both fast and reliable on my 4-5 year old note 9 pro phone. I just changed to a 13tp with 120 watt, let's see how that pans out
Yes, but...
edit: clarity
Apparently not
Yes, but...
edit: clarity
