Figured what out?
$219 Springer Nature book "Mastering Machine Learning: From Basics to Advanced" was written with a chatbot
Bruce Lee, Jackie Chan and ‘A Better Tomorrow’: AI-Powered Kung Fu Film Plan Debuts in Shanghai
Study: US kids who said their social media, phone, or video game use was “addictive” were 2x-3x more likely to have thoughts of suicide or self-harm by age 14
