    It's got to be a lie
    1,000 charge cycles: OnePlus 13
    Hmm. This one has newer silicone-carbon lithium-ion batteries, which should actually increase charge cycles, so what's happening here?
  • 1,000 charge cycles: OnePlus 13
    Isn't one plus one of the brands that has their own fast charging tech, that's extra fast?
  • Isn't one plus one of the brands that has their own fast charging tech, that's extra fast?
    Xiaomi has faast charge, and it (33watt) has worked both fast and reliable on my 4-5 year old note 9 pro phone. I just changed to a 13tp with 120 watt, let's see how that pans out 🔥😋
    Yes, but...
    edit: clarity
  • Wow. This is excellent for Samsung users.
    Apparently not
    Yes, but...
    edit: clarity
  • 18 Stimmen
    6 Aufrufe
    This isn't the Cthulhu universe. There isn't some horrible truth ChatGPT can reveal to you which will literally drive you insane. Some people use ChatGPT a lot, some people have psychotic episodes, and there's going to be enough overlap to write sensationalist stories even if there's no causative relationship. I suppose ChatGPT might be harmful to someone who is already delusional by (after pressure) expressing agreement, but I'm not sure about that because as far as I know, you can't talk a person into or out of psychosis.
  • 66 Stimmen
    13 Aufrufe
    FYI- insurance company data breaches impact more than just customers. I had my identity stolen a few years ago because a small car insurance company I've never heard of was able to buy data on me from my state's government to build a potential customer profile, and then they got hacked. I would assume Aflac has data on just about everyone in the US.
  • 144 Stimmen
    16 Beiträge
    26 Aufrufe
    B
    I know there decent alternatives to SalesForce, but I’m not sure what you’d replace Slack with. Teams is far worse in every conceivable way and I’m not sure if there’s anything else out there that isn’t already speeding down the enshittification highway.
  • Is AI Apocalypse Inevitable? - Tristan Harris
    121 Stimmen
    11 Beiträge
    21 Aufrufe
    V
    Define AGI, because recently the definition is shifting down to match LLM. In fact we can say we achieved AGI now because we have machine that answers questions. The problem will be when the number of questions will start shrinking not because of number of problems but number of people that understand those problems. That is what is happening now. Don't believe me, read the statistics about age and workforce. Now put it into urgent need to something to replace those people. After that think what will happen when all those attempts fail.
  • uBlockOrigin is porting uBOL to iOS and macOS
    325 Stimmen
    30 Beiträge
    49 Aufrufe
    Will never happen unfortunately
  • Sunsetting the Ghostery Private Browser
    33 Stimmen
    13 Aufrufe
    P
    Sunsetting Dawn? Of course
  • 24 Stimmen
    7 Aufrufe
    toastedravioli@midwest.socialT
    Im all for making the traditional market more efficient and transparent, if blockchain can accommodate that, so long as we can also make crypto more like the traditional market. At least in terms of criminalizing shit that would obviously be illegal to do with securities
  • The bots are among us.
    9 Aufrufe
    yerbouti@sh.itjust.worksY
    Yeah she was on to something with the layers, but screw it up. I’m sure the models got better since.
