Jobs figured everything out a long time ago. Why are you desecrating his memory?
Figured what out?
finally some good news for us Samsung victims/owners.
What are you talking about? The article doesn't mention him.
Figured what out?
As Data Centers Proliferate, Illinois Communities Grapple with How to Supply the Necessary Water. "This isn’t reused wastewater. This is drinking water”
OpenAI supremo Sam Altman says he 'doesn't know how' he would have taken care of his baby without the help of ChatGPT
Discord unveils Discord Orbs, a new in-app currency that users can earn by completing Quests, which reward participants who interact with ads
