Same, got mine in early 2020 and the battery is still at 87% capacity.
Jobs figured everything out a long time ago. Why are you desecrating his memory?
Figured what out?
finally some good news for us Samsung victims/owners.
What are you talking about? The article doesn't mention him.
Figured what out?
To land Meta’s massive $10 billion data center, Louisiana pulled out all the stops. Will it be worth it?
People Are Being Involuntarily Committed, Jailed After Spiraling Into "ChatGPT Psychosis"
Duolingo CEO says AI is a better teacher than humans—but schools will exist ‘because you still need childcare’
