I agree and it would be much better if people would use Signal instead of WhatsApp, but I think there's still one problem.
This makes switching very hard even for a nerd like me, because if Signal is not "perfect" it means that I will have to switch again at some point and lose everything again.I've been using Signal for years and my database was getting really bloated with media, attachments, etc but I didn't want to delete it all. I used this and it's incredible:
GitHub - bepaald/signalbackup-tools: Tool to work with Signal Backup files.
Tool to work with Signal Backup files. Contribute to bepaald/signalbackup-tools development by creating an account on GitHub.
GitHub (github.com)
Just make a backup from within signal, copy that backup file to your PC, then run this tool. The commands I used make an HTML webpage that looks just like the signal messenger, along with a way of searching your messages. You can choose different commands to export however you like.
I used:
signalbackup-tools [input] [passphrase] --exporthtml [directory] --split --searchpage --originalfilenames
So while this doesn't help you move off your current messenger, you don't have to worry that your data/messages will be lost in Signal.
Basically Signal but without the weakness of a phone number & runs on a Tor-like network. It's still a work-in-progress thing but you CAN use it to send messages
Nah, that would be Matrix, XMPP, DeltaChat or SimpleX
Ya it’d be better if it didn’t require a phone number but it’s a solid start as it’s build up a user base over the past decade. Matrix is good but I know far less people that use it and it’ll be a long time of growing with nerdy/geeky communities before it starts getting more mainstream users
Have a look here: https://www.messenger-matrix.de/messenger-matrix-en.html
I like the comparison and prefer simplex as an replacement to Signal in the Future.
Self hosted Matrix Servers are a good idea aswell if you have the money and knowledge. -
Like Matrix.
Matrix still has it's problems. All the meta data is still saved on every server permanently.
There is still space to improve from there.
telegram much better
By features, yes. By 10 miles.
Privacy? It isn't driving anymore at this point.
any proofs?
This makes switching very hard even for a nerd like me, because if Signal is not "perfect" it means that I will have to switch again at some point and lose everything again.Thats a problem with silos (where one owner hosts all the servers) in general. You will have to switch the entire ecosystem once the inevitable enshitification sets in. It's a good idea to switch to something open source and federated (where many different non profit organisations and even self hosting individuals host many different servers).
That way you can migrate your history and contacts to another server of necessary but never have to switch the ecosystem again. Think it how email works, it's the best known federated system. If you don't like you email provider anymore you can just chose another one and still keep your contacts and messages on a client like Thunderbird forever.
Xmpp and matrix are the hottest candidates in my opinion, but you can check the messenger matrix that was linked in a comment above to see what suits you best. -
Signal is on F-Droid.
Why not Signal?
A few essays on communism
essays (dessalines.github.io)
Most of the alternatives mentioned have such low adoption that they aren't truly viable options yet - no matter how much we wish otherwise.
And I say that not as a critic - I actually use Matrix, XMPP, and Jitsi myself. But guess how many of my friends, family, or colleagues are on them?
Exactly.
That’s why I recommend Signal. At least there, people are likely to find folks they already know.
This makes switching very hard even for a nerd like me, because if Signal is not "perfect" it means that I will have to switch again at some point and lose everything again.You can save any media you care about. And Signal can backup your chats if that history is important to you.
any proofs?
To get encryption one must start a "secret chat". It's an opt-in! Regular users will not even know the option exists, that's how well hidden it is.
Regular chats? Plainly readable on the server.
It used to function as a fallback SMS/MMS messenger (like how iMessage does) but when Google started moving to convert Android from SMS/MMS to RCS Signal made the hard decision to cut the fallback functionality rather than follow Google's new framework.
I personally hope once the dust settles Signal designs a RCS engine and restores the fallback functionality.
Sure, but if I switch from Signal to another potentially better messaging app down the line my chat history will get fragmented
Jami*
Matrix isn’t necessarily p2p
Xmpp and matrix are the hottest candidates in my opinion, but you can check the messenger matrix that was linked in a comment above to see what suits you best.Well said, the problem really is that Signal isn't federated. I'm keeping an eye on Matrix for now.
Fair. There is Molly on fdroid if you like.
Can't find it though
No. XMPP would be the best choice.
Bill Atkinson, visionary engineer behind the Apple Macintosh operating system, dies at 74
Hong Kong workers strike against the algorithmic exploitation of Keeta, a food delivery platform
Xinbi: The $8 Billion Colorado-Incorporated Marketplace for Pig-Butchering Scammers and North Korean Hackers
We have reached the “severed fingers and abductions” stage of the crypto revolution - Ars Technica
Surprise! People don't want AI deciding who gets a kidney transplant and who dies or endures years of misery
