I think it was meant as a security feature in case someone picked up your unlocked phone. It perhaps someone cracked your front screen passcode.
I know if you forget your password and have to reset it you lose all previous conversations. It’s very secure this way. Bit of a pain.. but secure.That’s not even what it is lol.
And as the other commenter alluded to, defaults matter. You’re not replacing the thing everyone is already using by pitching “here’s an alternative that is better in ways which don’t affect your usage at all, and also you have to dig into the settings to turn off the optional daily popups”
I use obtainium to install it and it works flawlessly. The reason they don't publish it elsewhere is due to licences and push notifications iirc
It may not be the holy grail, but moving away from Meta-owned Whatsapp is already a pretty significant improvementBe careful with that ol' Chestnut. Circumstances may dictate perfection, where less than such may be catastrophic.
Wasn't WhatsApp essentially built from Signal's base protocol anyway? Why use the meta clone when the original is right there?
No. WhatsApp came first, but later adopted Signal's key exchange and encryption. WhatsApp was an independent company for years and had rejected several acquisition offers, but $19 billion is a big number.
One of WhatsApp's founders is now chairman of the Signal Foundation and a major financial backer of the project.
Fair. There is Molly on fdroid if you like.
Molly is great.
That's a risk, and a reason I'd like to see something federated succeed in this space. Unfortunately neither Matrix nor XMPP has managed to achieve quite the level of UX necessary for mainstream adoption, nor have the average person's tech skills and comfort level improved.
Signal's status as a well-funded nonprofit gives me hope that the current situation is reasonably stable.
In that case it wouldn't be "good enough". But I don't think this is such an all-or-nothing situation.
You can use Molly from F-Droid. They even have a full FOSS version that you can set up a self hosted notification socket for, to avoid Google Firebase.
It may not be the holy grail, but moving away from Meta-owned Whatsapp is already a pretty significant improvementI agree and it would be much better if people would use Signal instead of WhatsApp, but I think there's still one problem.
This makes switching very hard even for a nerd like me, because if Signal is not "perfect" it means that I will have to switch again at some point and lose everything again. -
Signal is very actively and directly working to pioneer a new financial model for long term software business stability that does not rely on surveillance capitalism. Your experience with young companies enshittifying into monsters is the natural cycle for the surveillance economy, and if Signal does eventually go that way it will be a profound disappointment, but I expect the foundation would rather die first. Check out this interview from last year with the president of the Signal Foundation for more depth on that.
Like Matrix.
I don't know, the GrapheneOS folks say that F-Droid is a potential security catastrophe.
You can find Molly from Accrescent (and apparently also from F-Droid if you must use that), which is not so much a security catastrophe.
That blog post was my reason to double down on Matrix.
It may not be the holy grail, but moving away from Meta-owned Whatsapp is already a pretty significant improvementWhy not Signal?
A few essays on communism
essays (dessalines.github.io)
telegram much better
YouTube relaxes moderation rules to allow more controversial content. Videos are allowed if "freedom of expression value may outweigh harm risk"
Telegram, the FSB, and the Man in the Middle: The technical infrastructure that underpins Telegram is controlled by a man whose companies have collaborated with Russian intelligence services.
