  • Seven Goldfish
    4 Stimmen
  • 310 Stimmen
    37 Beiträge
    Same, especially when searching technical or niche topics. Since there aren't a ton of results specific to the topic, mostly semi-related results will appear in the first page or two of a regular (non-Gemini) Google search, just due to the higher popularity of those webpages compared to the relevant webpages. Even the relevant webpages will have lots of non-relevant or semi-relevant information surrounding the answer I'm looking for. I don't know enough about it to be sure, but Gemini is probably just scraping a handful of websites on the first page, and since most of those are only semi-related, the resulting summary is a classic example of garbage in, garbage out. I also think there's probably something in the code that looks for information that is shared across multiple sources and prioritizing that over something that's only on one particular page (possibly the sole result with the information you need). Then, it phrases the summary as a direct answer to your query, misrepresenting the actual information on the pages they scraped. At least Gemini gives sources, I guess. The thing that gets on my nerves the most is how often I see people quote the summary as proof of something without checking the sources. It was bad before the rollout of Gemini, but at least back then Google was mostly scraping text and presenting it with little modification, along with a direct link to the webpage. Now, it's an LLM generating text phrased as a direct answer to a question (that was also AI-generated from your search query) using AI-summarized data points scraped from multiple webpages. It's obfuscating the source material further, but I also can't help but feel like it exposes a little of the behind-the-scenes fuckery Google has been doing for years before Gemini. How it bastardizes your query by interpreting it into a question, and then prioritizes homogeneous results that agree on the "answer" to your "question". For years they've been doing this to a certain extent, they just didn't share how they interpreted your query.
  • 227 Stimmen
    52 Beiträge
    4 Aufrufe
    Yeah, hence the qualifications haha
  • 61 Stimmen
    11 Beiträge
    2 Aufrufe
    K
    If you use LLMs like they should be, i.e. as autocomplete, they're helpful. Classic autocomplete can't see me type "import" and correctly guess that I want to import a file that I just created, but Copilot can. You shouldn't expect it to understand code, but it can type more quickly than you and plug the right things in more often than not.
  • 25 Stimmen
    9 Beiträge
    7 Aufrufe
    I didn't care much about arc because it was chromium, but damn this is just bland and uninteresting compared to it
    6 Aufrufe
    If you're a developer, a startup founder, or part of a small team, you've poured countless hours into building your web application. You've perfected the UI, optimized the database, and shipped features your users love. But in the rush to build and deploy, a critical question often gets deferred: is your application secure? For many, the answer is a nervous "I hope so." The reality is that without a proper defense, your application is exposed to a barrage of automated attacks hitting the web every second. Threats like SQL Injection, Cross-Site Scripting (XSS), and Remote Code Execution are not just reserved for large enterprises; they are constant dangers for any application with a public IP address. The Security Barrier: When Cost and Complexity Get in the Way The standard recommendation is to place a Web Application Firewall (WAF) in front of your application. A WAF acts as a protective shield, inspecting incoming traffic and filtering out malicious requests before they can do any damage. It’s a foundational piece of modern web security. So, why doesn't everyone have one? Historically, robust WAFs have been complex and expensive. They required significant budgets, specialized knowledge to configure, and ongoing maintenance, putting them out of reach for students, solo developers, non-profits, and early-stage startups. This has created a dangerous security divide, leaving the most innovative and resource-constrained projects the most vulnerable. But that is changing. Democratizing Security: The Power of a Community WAF Security should be a right, not a privilege. Recognizing this, the landscape is shifting towards more accessible, community-driven tools. The goal is to provide powerful, enterprise-grade protection to everyone, for free. This is the principle behind the HaltDos Community WAF. It's a no-cost, perpetually free Web Application Firewall designed specifically for the community that has been underserved for too long. It’s not a stripped-down trial version; it’s a powerful security tool designed to give you immediate and effective protection against the OWASP Top 10 and other critical web threats. What Can You Actually Do with It? With a community WAF, you can deploy a security layer in minutes that: Blocks Malicious Payloads: Get instant, out-of-the-box protection against common attack patterns like SQLi, XSS, RCE, and more. Stops Bad Bots: Prevent malicious bots from scraping your content, attempting credential stuffing, or spamming your forms. Gives You Visibility: A real-time dashboard shows you exactly who is trying to attack your application and what methods they are using, providing invaluable security intelligence. Allows Customization: You can add your own custom security rules to tailor the protection specifically to your application's logic and technology stack. The best part? It can be deployed virtually anywhere—on-premises, in a private cloud, or with any major cloud provider like AWS, Azure, or Google Cloud. Get Started in Minutes You don't need to be a security guru to use it. The setup is straightforward, and the value is immediate. Protecting the project, you've worked so hard on is no longer a question of budget. Download: Get the free Community WAF from the HaltDos site. Deploy: Follow the simple instructions to set it up with your web server (it’s compatible with Nginx, Apache, and others). Secure: Watch the dashboard as it begins to inspect your traffic and block threats in real-time. Security is a journey, but it must start somewhere. For developers, startups, and anyone running a web application on a tight budget, a community WAF is the perfect first step. It's powerful, it's easy, and it's completely free.
  • The AI girlfriend guy - The Paranoia Of The AI Era
    6 Stimmen
    3 Aufrufe
    4 Aufrufe
    P
    It's a shame. AI has potential but most people just want to exploit its development for their own gain.
