Japan using generative AI less than other countries
  • 426 Stimmen
    30 Beiträge
    119 Aufrufe
    Every single opportunity, however petty, to ensure we become more miserable evwry day.
  • Grok, Elon Musk's AI chatbot, seems to get right-wing update
    185 Stimmen
    13 Beiträge
    81 Aufrufe
    Yep. Pretty sure that was deliberate on Musk's (or his cronies) part. Imagine working at X and being told by your boss "I'd like you to make the bot more racist please." "Can you convince it that conspiracy theories are real?"
  • No, Social Media is Not Porn
    21 Stimmen
    28 Aufrufe
    Z
    This feels dystopian and like overreach. But that said, there definitely is some porn on the 4 platforms they cited. It's an excuse sure, but let's also not deny reality.
  • 456 Stimmen
    48 Beiträge
    97 Aufrufe
    That's good to know, thanks.
  • 221 Stimmen
    16 Beiträge
    88 Aufrufe
    V
    Does it mean that some people take orders from AI and don't know it's AI ?
  • I am disappointed in the AI discourse
    7 Stimmen
    27 Beiträge
    107 Aufrufe
    artocode404@lemmy.dbzer0.comA
    I apologize that apparently Lemmy/Reddit people do not have enough self-awareness to accept good criticism, especially if it was just automatically generated and have downloaded that to oblivion. Though I don't really think you should respond to comments with a chatGPT link, not exactly helpful. Comes off a tad bit AI Bro...
  • 36 Stimmen
    9 Beiträge
    14 Aufrufe
    It's also much easier to implement.
    33 Aufrufe
    Forgive me for not explaining better. Here are the terms potentially needing explanation. Provisioning in this case is initial system setup, the kind of stuff you would do manually after a fresh install, but usually implies a regimented and repeatable process. Virtual Machine (VM) snapshots are like a save state in a game, and are often used to reset a virtual machine to a particular known-working condition. Preboot Execution Environment (PXE, aka ‘network boot’) is a network adapter feature that lets you boot a physical machine from a hosted network image rather than the usual installation on locally attached storage. It’s probably tucked away in your BIOS settings, but many computers have the feature since it’s a common requirement in commercial deployments. As with the VM snapshot described above, a PXE image is typically a known-working state that resets on each boot. Non-virtualized means not using hardware virtualization, and I meant specifically not running inside a virtual machine. Local-only means without a network or just not booting from a network-hosted image. Telemetry refers to data collecting functionality. Most software has it. Windows has a lot. Telemetry isn’t necessarily bad since it can, for example, help reveal and resolve bugs and usability problems, but it is easily (and has often been) abused by data-hungry corporations like MS, so disabling it is an advisable precaution. MS = Microsoft OSS = Open Source Software Group policies are administrative settings in Windows that control standards (for stuff like security, power management, licensing, file system and settings access, etc.) for user groups on a machine or network. Most users stick with the defaults but you can edit these yourself for a greater degree of control. Docker lets you run software inside “containers” to isolate them from the rest of the environment, exposing and/or virtualizing just the resources they need to run, and Compose is a related tool for defining one or more of these containers, how they interact, etc. To my knowledge there is no one-to-one equivalent for Windows. Obviously, many of these concepts relate to IT work, as are the use-cases I had in mind, but the software is simple enough for the average user if you just pick one of the premade playbooks. (The Atlas playbook is popular among gamers, for example.) Edit: added explanations for docker and telemetry
