JD Vance gets suspended from Bluesky 'just 12 minutes after first post': reports
  • 965 Stimmen
    101 Beiträge
    956 Aufrufe
    D
    That's always worth considering. A phone app doesn't take a big operating budget to launch and maintain. Especially for state-actors.
  • Russia frees REvil hackers after sentencing
    37 Stimmen
    47 Aufrufe
    What makes even more sense is that they now might be secretly forced to hack for the government in exchange for bread and water and staying out of prison.
  • 893 Stimmen
    134 Beiträge
    5k Aufrufe
    Y
    Yup, but the control mechanisms are going to shit, because it sounds like they are going to maybe do a half assed rollout
    17 Aufrufe
  • Is Matrix cooked?
    101 Stimmen
    54 Beiträge
    422 Aufrufe
    W
    Didn't know it only applied to UWP apps on Windows. That does seem like a pretty big problem then. it is mostly for compatibility reasons. no win32 programs are equipped to handle such granular permissions and sandboxing, they are all made with the assumption that they have access to whatever they need (other than other users' resources and things that require elevation). if Microsoft would have made that limitation to every kind of software, that Windows version would have probably been a failure in popularity because lots of software would have broken. I think S editions of windows is how they tried to go in that direction, with a more drastic way of simply just dropping support for 3rd party win32 programs. I don't still have a Mac readily available to test with but afaik it is any application that uses Apple's packaging format. ok, so if you run linux or windows utils in a compatibility layer, they still have less of a limited access? by which I mean graphical utilities. just tried with firefox, for macos it wanted to give me an .iso file (???) if so, it seems apple is doing roughly the same as microsoft with uwp and the appx format, and linux with flatpak: it's a choice for the user
  • 186 Stimmen
    18 Beiträge
    132 Aufrufe
    N
    Part of the reason for my use of "might".
  • AI cheating surge pushes schools into chaos
    45 Stimmen
    25 Beiträge
    220 Aufrufe
    Sorry for the late reply, I had to sit and think on this one for a little bit. I think there are would be a few things going on when it comes to designing a course to teach critical thinking, nuances, and originality; and they each have their own requirements. For critical thinking: The main goal is to provide students with a toolbelt for solving various problems. Then instilling the habit of always asking "does this match the expected outcome? What was I expecting?". So usually courses will be setup so students learn about a tool, practice using the tool, then have a culminating assignment on using all the tools. Ideally, the problems students face at the end require multiple tools to solve. Nuance mainly naturally comes with exposure to the material from a professional - The way a mechanical engineer may describe building a desk will probably differ greatly compared to a fantasy author. You can also explain definitions and industry standards; but thats really dry. So I try to teach nuances via definitions by mixing in the weird nuances as much as possible with jokes. Then for originality; I've realized I dont actually look for an original idea; but something creative. In a classroom setting, you're usually learning new things about a subject so a student's knowledge of that space is usually very limited. Thus, an idea that they've never heard about may be original to them, but common for an industry expert. For teaching originality creativity, I usually provide time to be creative & think, and provide open ended questions as prompts to explore ideas. My courses that require originality usually have it as a part of the culminating assignment at the end where they can apply their knowledge. I'll also add in time where students can come to me with preliminary ideas and I can provide feedback on whether or not it passes the creative threshold. Not all ideas are original, but I sometimes give a bit of slack if its creative enough. The amount of course overhauling to get around AI really depends on the material being taught. For example, in programming - you teach critical thinking by always testing your code, even with parameters that don't make sense. For example: Try to add 123 + "skibbidy", and see what the program does.
  • 48 Stimmen
    14 Beiträge
    123 Aufrufe
    B
    Take a longer text (like 70 pages or so) and try to delete the first 30 pages.
