[Important] Catbox Needs Your Help
  • What is the value add of this product? The donors and recipients still need to set up a Monero wallet and everything to use the service. A recipient may just as well instead use any other means (social media, etc.) to announce that they are accepting Monero donations at xyz address.
    Mainly goal setting and tracking. You could say, for example, that your goal is to raise 50 Monero, and each donation to that address will show up on the site as adding to it, and the donor can leave you a message if they wish.
    It allows everybody to see exactly how close you are to your 50 Monero goal, etc.
  • but they also have illegitimate uses that (what I understand to be) a one-man team is likely not prepared to deal with
    This would be somewhat believable excuse if they only blocked uploading/posting under VPNs. But they block viewing under VPNs as well, which you only do if your sole purpose is logging IP addresses of viewers. In this scenario catbox images posted to Lemmy for example, they don't only reveal your IP the moment they are loaded when you scroll your feed, they also associate it with the site from where the request was initiated (your Lemmy instance).
    With CSAM, you want to block uploading and downloading, because both are problematic for a host.
    I'm 99% sure it doesn't work that way. The Lemmy instance caches a preview image for posted links. But scrolling past without clicking a link will not expose your IP to Catbox unless you have an auto-preview setting enabled that opens/caches every link you scroll past automatically, which I don't believe is enabled by default.
  • With CSAM, you want to block uploading and downloading, because both are problematic for a host.
    At that point, if such content is already posted there and available for download, it doesn't matter if it is only allowed to be downloaded via clearnet or VPNs as well. Blocking VPNs doesn't make any difference here.
    I’m 99% sure it doesn’t work that way. The Lemmy instance caches a preview image for posted links. But scrolling past without clicking a link will not expose your IP to Catbox unless you have an auto-preview setting enabled that opens/caches every link you scroll past automatically, which I don’t believe is enabled by default.
    I've seen a debate regarding lemmynsfw with some people asking to turn off caching/proxying for images. I don't know what's their current status on this, but on my instance even thumbnails were not visible for catbox images. I'm not sure if it's disabled or it's the instance server itself having trouble accessing catbox.
    My understanding is that it's for tracking/reporting purposes, and to mitigate future offenses by banning those IPs. You can report an IP to an ISP for CSAM violations, but it's not as useful when the user's on a VPN.
    Yeah, I've also noticed that Catbox links don't seem to generate previews on Mbin, as well, so I suspect that may be a Catbox block of some sort. That's interesting... I wonder if that causes a Lemmy instance to attempt a live preview instead of giving you a cached one. If so, that seems like something that probably shouldn't be in place, IMO.
  • My understanding is that it’s for tracking/reporting purposes, and to mitigate future offenses by banning those IPs. You can report an IP to an ISP for CSAM violations, but it’s not as useful when the user’s on a VPN.
    Don't think even the most extreme actors go that far, link could be opened accidentally, etc...
    Anyway, from what another poster here linked, it looks like Catbox might actually not be banning any VPNs at all on its own, this might be some kind of middleware/routing infrastructure issue.
  • Do you use Verizon for Internet? It's been my experience that the only way I can open catbox links is if I'm not connected solely to Verizon's network.
  • tl;dr - Patreon deleted my page, refused to elaborate, and Catbox is now short $1,300~ in reoccurring income to pay the bill.
    Support Catbox Here
    I use catbox to post videos and moving webp files to lemmy 😭
    edit: to be clear I'm not affiliated with catbox, i just shared
    How is catbox hosted?
    If they're renting VPS hardware, then they're getting scammed.
    They should set up self hosting with their own hardware and a VPN. It will cut down on the recurring costs significantly.
    Don't pay for others' stupidity, if you can avoid it.
  • Any reliable alternatives you know of?
    We should normalize just sending them money directly through crypto.
    Why have more middlemen than we need? It it because we're idiots getting taken for a ride?
    I know what I'll put my money on, every time.
    Support Catbox Here
    I can never see catbox files anyways
  • I can never see catbox files anyways
    That's likely caused by your DNS provider blocking it.
