Researchers finds high levels of dangerous air particles(PM2.5) in air near electric vehicle fast charging stations.
    • At the charging stations, daily concentrations of dangerous air particles, known as PM2.5, ranged from 7.3 to 39.0 micrograms per cubic meter.
    • Urban sites without fast-charging stations had concentrations of PM2.5 ranging from only 3.6 to 12.4 micrograms per cubic meter.
    • The tiny particles likely come from particle resuspension around Direct Current Fast Charging power cabinets. Cooling fans designed to prevent the electronics from overheating can also stir up dust and particles from internal surfaces.
    Can't wait for the "electric cars are killing children" research next
    a) that doesn't really sound like the fault of EVs or the charging stations themselves. Any sort of very moderate air current would cause the same problem.
    b) that sounds pretty easy to fix with some filters simple pleated filters, and that would leave the surrounding environment cleaner than they used to be.
    From the people who think windmills cause cancer?
    a) that doesn’t really sound like the fault of EVs or the charging stations themselves. Any sort of very moderate air current would cause the same problem.
    Excactly. The stations themselves don't create particles but magnetic fields from the high voltage DC lines and cooling fans just pick them up from the ground and back to air. It's quite misleading to claim this is “Fine particulate matter emissions from electric vehicle fast charging stations” as the stations just redistribute existing emissions.
    Obviously this is not a good thing, but the underlying cause is something else than these stations, I'd bet considerable amount of it comes from combustion engines. And as you said, simple filters should fix the problem and clean up the pollution from environment as well.
    Also they're likely in more densely populated areas which already have lower air quality.
    Urban backgrounds n=4 and gas stations n=8
    are you fucking kidding me
    Why higher particulate matter was found in the air at EV-charging stations?
    Because your sample sizes are shit, which means your methodology is probably also shit and the report carries less weight than a shampoo advert statistics
    Now do PM and VOC levels at petrol stations.
    Then PM and VoC levels on roads entirely occupied by combustion vehicles, and entirely occupied by electric vehicles.
  • Also they're likely in more densely populated areas which already have lower air quality.
    This seems accounted for since the comparative samples are from "similarly urban areas"
  • Now do PM and VOC levels at petrol stations.
    It's like this is perfectly crafted to demonstrate a spurious correlation.
    I get what you're saying but I'm not seeing this as "electric cars suck" but more as "we found another place where we can improve"
    This seems to me an issue that can be fixed with a few air filters which would require very infrequent replacements
    I just web searched the names of this research team... The last one on the list is a teeth-puller, folks.
    Yuan Yao, teacher of sustainable systems.
    Muchuan Niu, UCLA student, MS in Environmental Sciences.
    Haoxuan Chen, Stanford student, machine learning.
    Qiao Yu, Shanghai A.I. Laboratory.
    Qingyang Wu, private A.I. developer.
    Yuhang Li, student, Art History, A.I. cloud data processor.
    Yijie Zhang, UCLA student, A.I. machine learning.
    Aydogan Ozcan, UCLA, computational imaging and deep learning optics.
    Michael Jerrett, teacher at UCLA, geographic information systems science, spatial exposure science.
    Yifang Zhu, student in Environmental Sciences, associate of UCLA Fielding School project group, funds and\or law underwriter for Mobility Justice Frameworks (Mobility Justice is an almost eco-extremist entity that also uses racial cause to gather USDOT public funding).
  • I just web searched the names of this research team... The last one on the list is a teeth-puller, folks.
    My bottom-of-the-rabbit-hole best guess. Create premature science data media for campaigns for lawmakers to push for more greenspaces in urban areas.
    Look at the map this is just higher near larger population, Correlation vs. Causation. This smells like bull shit.
  • Look at the map this is just higher near larger population, Correlation vs. Causation. This smells like bull shit.
    A research participant, Yifang Zhu, is tied to a thing called Mobility Justice Frameworks. It's pushing for greenspaces in urban areas, including making existing infrastructures look bad for its cause(s).
    The research team has more A.I. tools than proper researching. It's odd.
    Jesus they will release any study to try and smear electric. It's the same argument as cigs vs vapes. Yes they're both bad and not the best solution, but one is obviously better than the other. Plus how are they separating contamination of the charging stations from any other area where normal ass cars operate. There's just as much of a chance if not more that those particles are from the gas vehicles driving around, and not something specific to the chargers.
  • Jesus they will release any study to try and smear electric. It's the same argument as cigs vs vapes. Yes they're both bad and not the best solution, but one is obviously better than the other. Plus how are they separating contamination of the charging stations from any other area where normal ass cars operate. There's just as much of a chance if not more that those particles are from the gas vehicles driving around, and not something specific to the chargers.
    They're not separating data throughly. Researcher Yifang Zhu, over many publishings, mainly gathers and publishes raw findings. Such as... (summarizing) "Children are at risk due to immature respiratory systems and faster breathing rates... by traveling in diesel powered school buses in my South Texas study."
    Source- https://scholar.google.com/citations?view_op=view_citation&hl=en&user=kvSIKM8AAAAJ&cstart=20&pagesize=80&citation_for_view=kvSIKM8AAAAJ%3A5nxA0vEk-isC
    Do you not see the summary text in your front end, or did you just not read it? This is what it looks like on the default web front end on my instance:
    Dafuq.
    This is the craziest reaction to knowledge
    Knowing something new we didn't before means..... We know more now.
    Stop trying to politicize this.
    This just means there is room to improve, this is a good thing.
  • 42 Stimmen
    9 Beiträge
    12 Aufrufe
    F
    I imagine not, though I haven't looked into it.
  • 93 Stimmen
    7 Aufrufe
    I wouldn't call it unprecedented, just more obvious
  • Bill Gates and Linus Torvalds meet for the first time.
    441 Stimmen
    44 Beiträge
    72 Aufrufe
    That must have taken some diplomacy, but it would have been even more impressive to have convinced Stallman to come too
  • Sitting up and waiting.
    5 Stimmen
    12 Aufrufe
    What new AI slop hell is this?
  • The AI-powered collapse of the American tech workfoce
    4 Stimmen
    12 Aufrufe
    roofuskit@lemmy.worldR
    The biggest tech companies are still trimming from pandemic over hiring. Smaller companies are still snatching workers up. And you also have companies trimming payroll for the coming Trump recession. Neither have anything to do with AI.
  • New Cars Don't All Come With Dipsticks Anymore, Here's Why
    2 Stimmen
    22 Beiträge
    33 Aufrufe
    The U660F transmission in my wife's 2015 Highlander doesn't have a dipstick. Luckily that transmission is solid and easy to service anyway, you just need a skinny funnel to fill it.
  • 27 Stimmen
    10 Aufrufe
    I really wish their whole lap-dock concept had succeeded. Or at least ran a few more generations, so I could get an upgraded model with USBc
    15 Aufrufe
    P
    Outlook.... Ok Pretty solid Bahaha hahahahaha Sorry. Outlook is a lot of things. "Gooey crap" would be one way to describe it, but "solid"? Yeah, no. Gmail is (well, was) pretty solid. There are a lot of other webmail providers out there, including self hosted options and most are pretty solid, yeah. Outlook, though? It's a shit show, it's annoying. Do you love me? Please love me, please give feedback, please give feedback again, please look at this, hey am I the best? Am I.. STFU YOU PIECE OF CRAP! Can you PLEASE just let me do my email without being an attention whore every hour? Even down to the basics. Back button? "What is that? Never heard of it, can't go back to the message I just was on because I'm Microsoft software and so half baked." Having two tabs open? "Oh noes, now I get scawed, now I don't know how to manage sessions anymore, better just sign you out everywhere." What is it with Microsoft and not being able to do something basic as sessions normal? I'm not even asking for good, definitely not "awesome", just normal, and that is already too much to ask. Try running it in Firefox! I'm sure it's totally not on purpose, just "oopsie woopsie poopsie" accidentally bwoken. Maybe it's working again today, who knows, tomorrow it'll be broken again. I run everything on Firefox except the Microsoft sites, they have to be in chrome because fuck you, that's why. Seriously, I can't take any Microsoft software seriously at this point, and all of it is on its way out in our company, I'm making sure of that
