Dank #Spahn ist mein Ansehen an die #Politik noch weiter gesunken, als es vorher schon war.
Uncategorized
2 2 0
  • Autofahrer Denken, eine weitere Spur reduziert den Stau.
    Uncategorized
    frankm@nrw.socialF
    @jbm Politiker dürften in den meisten Fällen auch #AutoIdioten sein.
  • "M$ bastelt an einer Lösung"
    Uncategorized
    1 Aufrufe
    frankm@nrw.socialF
    @t3n Wogegen man sich heute alles wappnen muss. Danke für den Tipp.
  • In Athen werden Verkehrsverstöße jetzt digital erfasst und geahndet.
    Uncategorized
  • Error Loading Module './manage' in NodeBB Theme – Need Help Debugging
    Uncategorized
    11 Aufrufe
    baris@community.nodebb.orgB
    How are you rendering the template? Is your code on github?
  • Upgrade form 3.x to 4.x
    Uncategorized
    7 Aufrufe
    H
    Like I mentioned, I do not why @resvg/resvg-js-freebsd-x64 dissapears **$ npm i @resvg/resvg-js-freebsd-x64** npm warn deprecated osenv@0.1.5: This package is no longer supported. npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful. npm warn deprecated har-validator@5.1.5: this library is no longer supported npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported npm warn deprecated glob@7.1.7: Glob versions prior to v9 are no longer supported npm warn deprecated glob@7.1.7: Glob versions prior to v9 are no longer supported npm warn deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details. npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142 added 546 packages, and audited 1462 packages in 8s 253 packages are looking for funding run `npm fund` for details 4 vulnerabilities (3 moderate, 1 high) Some issues need review, and may require choosing a different dependency. Run `npm audit` for details. **$ ./nodebb upgrade** Updating NodeBB... 1. Updating package.json file with defaults... OK 2. Bringing base dependencies up to date... started removed 1 package, and audited 916 packages in 3s 113 packages are looking for funding run `npm fund` for details 1 high severity vulnerability Some issues need review, and may require choosing a different dependency. Run `npm audit` for details. 3. Checking installed plugins for updates...Checking installed plugins and themes for updates... OK All packages up-to-date! 4. Updating NodeBB data store schema...Error occurred during upgrade: Error: Cannot find module '@resvg/resvg-js-freebsd-x64' Require stack: - /usr/home/hermes/domains/.../public_nodejs/node_modules/@resvg/resvg-js/js-binding.js - /usr/home/hermes/domains/.../public_nodejs/node_modules/@resvg/resvg-js/index.js - /usr/home/hermes/domains/.../public_nodejs/src/categories/icon.js - /usr/home/hermes/domains/.../public_nodejs/src/categories/index.js - /usr/home/hermes/domains/.../public_nodejs/src/privileges/helpers.js - /usr/home/hermes/domains/.../public_nodejs/src/privileges/global.js - /usr/home/hermes/domains/.../public_nodejs/src/privileges/index.js - /usr/home/hermes/domains/.../public_nodejs/src/posts/index.js - /usr/home/hermes/domains/.../public_nodejs/src/plugins/index.js - /usr/home/hermes/domains/.../public_nodejs/src/groups/index.js - /usr/home/hermes/domains/.../public_nodejs/src/user/index.js - /usr/home/hermes/domains/.../public_nodejs/src/events.js - /usr/home/hermes/domains/.../public_nodejs/src/meta/themes.js - /usr/home/hermes/domains/.../public_nodejs/src/meta/index.js - /usr/home/hermes/domains/.../public_nodejs/src/cli/upgrade.js - /usr/home/hermes/domains/.../public_nodejs/src/cli/index.js - /usr/home/hermes/domains/.../public_nodejs/nodebb at Function._resolveFilename (node:internal/modules/cjs/loader:1405:15) at defaultResolveImpl (node:internal/modules/cjs/loader:1061:19) at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1066:22) at Function._load (node:internal/modules/cjs/loader:1215:37) at TracingChannel.traceSync (node:diagnostics_channel:322:14) at wrapModuleLoad (node:internal/modules/cjs/loader:235:24) at Module.require (node:internal/modules/cjs/loader:1491:12) at require (node:internal/modules/helpers:135:16) at Object. (/usr/home/hermes/domains/.../public_nodejs/node_modules/@resvg/resvg-js/js-binding.js:1:2977) at Module._compile (node:internal/modules/cjs/loader:1734:14) 2025-07-04T13:33:16.087Z [4567/33883] - error: uncaughtException: Cannot find module '@resvg/resvg-js-freebsd-x64' Require stack: - /usr/home/hermes/domains/.../public_nodejs/node_modules/@resvg/resvg-js/js-binding.js - /usr/home/hermes/domains/.../public_nodejs/node_modules/@resvg/resvg-js/index.js - /usr/home/hermes/domains/.../public_nodejs/src/categories/icon.js - /usr/home/hermes/domains/.../public_nodejs/src/categories/index.js - /usr/home/hermes/domains/.../public_nodejs/src/privileges/helpers.js - /usr/home/hermes/domains/.../public_nodejs/src/privileges/global.js - /usr/home/hermes/domains/.../public_nodejs/src/privileges/index.js - /usr/home/hermes/domains/.../public_nodejs/src/posts/index.js - /usr/home/hermes/domains/.../public_nodejs/src/plugins/index.js - /usr/home/hermes/domains/.../public_nodejs/src/groups/index.js - /usr/home/hermes/domains/.../public_nodejs/src/user/index.js - /usr/home/hermes/domains/.../public_nodejs/src/events.js - /usr/home/hermes/domains/.../public_nodejs/src/meta/themes.js - /usr/home/hermes/domains/.../public_nodejs/src/meta/index.js - /usr/home/hermes/domains/.../public_nodejs/src/cli/upgrade.js - /usr/home/hermes/domains/.../public_nodejs/src/cli/index.js - /usr/home/hermes/domains/.../public_nodejs/nodebb Error: Cannot find module '@resvg/resvg-js-freebsd-x64' Require stack: - /usr/home/hermes/domains/.../public_nodejs/node_modules/@resvg/resvg-js/js-binding.js - /usr/home/hermes/domains/.../public_nodejs/node_modules/@resvg/resvg-js/index.js - /usr/home/hermes/domains/.../public_nodejs/src/categories/icon.js - /usr/home/hermes/domains/.../public_nodejs/src/categories/index.js - /usr/home/hermes/domains/.../public_nodejs/src/privileges/helpers.js - /usr/home/hermes/domains/.../public_nodejs/src/privileges/global.js - /usr/home/hermes/domains/.../public_nodejs/src/privileges/index.js - /usr/home/hermes/domains/.../public_nodejs/src/posts/index.js - /usr/home/hermes/domains/.../public_nodejs/src/plugins/index.js - /usr/home/hermes/domains/.../public_nodejs/src/groups/index.js - /usr/home/hermes/domains/.../public_nodejs/src/user/index.js - /usr/home/hermes/domains/.../public_nodejs/src/events.js - /usr/home/hermes/domains/.../public_nodejs/src/meta/themes.js - /usr/home/hermes/domains/.../public_nodejs/src/meta/index.js - /usr/home/hermes/domains/.../public_nodejs/src/cli/upgrade.js - /usr/home/hermes/domains/.../public_nodejs/src/cli/index.js - /usr/home/hermes/domains/.../public_nodejs/nodebb at Function._resolveFilename (node:internal/modules/cjs/loader:1405:15) at defaultResolveImpl (node:internal/modules/cjs/loader:1061:19) at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1066:22) at Function._load (node:internal/modules/cjs/loader:1215:37) at TracingChannel.traceSync (node:diagnostics_channel:322:14) at wrapModuleLoad (node:internal/modules/cjs/loader:235:24) at Module.require (node:internal/modules/cjs/loader:1491:12) at require (node:internal/modules/helpers:135:16) at Object. (/usr/home/hermes/domains/.../public_nodejs/node_modules/@resvg/resvg-js/js-binding.js:1:2977) at Module._compile (node:internal/modules/cjs/loader:1734:14) {"date":"Fri Jul 04 2025 15:33:16 GMT+0200 (czas środkowoeuropejski letni)","error":{"code":"MODULE_NOT_FOUND","requireStack":["/usr/home/hermes/domains/.../public_nodejs/node_modules/@resvg/resvg-js/js-binding.js","/usr/home/hermes/domains/.../public_nodejs/node_modules/@resvg/resvg-js/index.js","/usr/home/hermes/domains/.../public_nodejs/src/categories/icon.js","/usr/home/hermes/domains/.../public_nodejs/src/categories/index.js","/usr/home/hermes/domains/.../public_nodejs/src/privileges/helpers.js","/usr/home/hermes/domains/.../public_nodejs/src/privileges/global.js","/usr/home/hermes/domains/.../public_nodejs/src/privileges/index.js","/usr/home/hermes/domains/.../public_nodejs/src/posts/index.js","/usr/home/hermes/domains/.../public_nodejs/src/plugins/index.js","/usr/home/hermes/domains/.../public_nodejs/src/groups/index.js","/usr/home/hermes/domains/.../public_nodejs/src/user/index.js","/usr/home/hermes/domains/.../public_nodejs/src/events.js","/usr/home/hermes/domains/.../public_nodejs/src/meta/themes.js","/usr/home/hermes/domains/.../public_nodejs/src/meta/index.js","/usr/home/hermes/domains/.../public_nodejs/src/cli/upgrade.js","/usr/home/hermes/domains/.../public_nodejs/src/cli/index.js","/usr/home/hermes/domains/.../public_nodejs/nodebb"]},"exception":true,"os":{"loadavg":[9.13671875,9.947265625,10.07275390625],"uptime":11190617},"process":{"argv":["/usr/local/devil/node23/bin/node","/usr/home/hermes/domains/.../public_nodejs/nodebb","upgrade"],"cwd":"/usr/home/hermes/domains/.../public_nodejs","execPath":"/usr/local/devil/node23/bin/node","gid":1000,"memoryUsage":{"arrayBuffers":19195887,"external":23717600,"heapTotal":66514944,"heapUsed":41121032,"rss":144986112},"pid":33883,"uid":1537,"version":"v23.10.0"},"stack":"Error: Cannot find module '@resvg/resvg-js-freebsd-x64'\nRequire stack:\n- /usr/home/hermes/domains/.../public_nodejs/node_modules/@resvg/resvg-js/js-binding.js\n- /usr/home/hermes/domains/.../public_nodejs/node_modules/@resvg/resvg-js/index.js\n- /usr/home/hermes/domains/.../public_nodejs/src/categories/icon.js\n- /usr/home/hermes/domains/.../public_nodejs/src/categories/index.js\n- /usr/home/hermes/domains/.../public_nodejs/src/privileges/helpers.js\n- /usr/home/hermes/domains/.../public_nodejs/src/privileges/global.js\n- /usr/home/hermes/domains/.../public_nodejs/src/privileges/index.js\n- /usr/home/hermes/domains/.../public_nodejs/src/posts/index.js\n- /usr/home/hermes/domains/.../public_nodejs/src/plugins/index.js\n- /usr/home/hermes/domains/.../public_nodejs/src/groups/index.js\n- /usr/home/hermes/domains/.../public_nodejs/src/user/index.js\n- /usr/home/hermes/domains/.../public_nodejs/src/events.js\n- /usr/home/hermes/domains/.../public_nodejs/src/meta/themes.js\n- /usr/home/hermes/domains/.../public_nodejs/src/meta/index.js\n- /usr/home/hermes/domains/.../public_nodejs/src/cli/upgrade.js\n- /usr/home/hermes/domains/.../public_nodejs/src/cli/index.js\n- /usr/home/hermes/domains/.../public_nodejs/nodebb\n at Function._resolveFilename (node:internal/modules/cjs/loader:1405:15)\n at defaultResolveImpl (node:internal/modules/cjs/loader:1061:19)\n at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1066:22)\n at Function._load (node:internal/modules/cjs/loader:1215:37)\n at TracingChannel.traceSync (node:diagnostics_channel:322:14)\n at wrapModuleLoad (node:internal/modules/cjs/loader:235:24)\n at Module.require (node:internal/modules/cjs/loader:1491:12)\n at require (node:internal/modules/helpers:135:16)\n at Object. (/usr/home/hermes/domains/.../public_nodejs/node_modules/@resvg/resvg-js/js-binding.js:1:2977)\n at Module._compile (node:internal/modules/cjs/loader:1734:14)","trace":[{"column":15,"file":"node:internal/modules/cjs/loader","function":"Function._resolveFilename","line":1405,"method":"_resolveFilename","native":false},{"column":19,"file":"node:internal/modules/cjs/loader","function":"defaultResolveImpl","line":1061,"method":null,"native":false},{"column":22,"file":"node:internal/modules/cjs/loader","function":"resolveForCJSWithHooks","line":1066,"method":null,"native":false},{"column":37,"file":"node:internal/modules/cjs/loader","function":"Function._load","line":1215,"method":"_load","native":false},{"column":14,"file":"node:diagnostics_channel","function":"TracingChannel.traceSync","line":322,"method":"traceSync","native":false},{"column":24,"file":"node:internal/modules/cjs/loader","function":"wrapModuleLoad","line":235,"method":null,"native":false},{"column":12,"file":"node:internal/modules/cjs/loader","function":"Module.require","line":1491,"method":"require","native":false},{"column":16,"file":"node:internal/modules/helpers","function":"require","line":135,"method":null,"native":false},{"column":2977,"file":"/usr/home/hermes/domains/.../public_nodejs/node_modules/@resvg/resvg-js/js-binding.js","function":null,"line":1,"method":null,"native":false},{"column":14,"file":"node:internal/modules/cjs/loader","function":"Module._compile","line":1734,"method":"_compile","native":false}]} [hermes@s3]:<~/domains/.../public_nodejs>$
    18 Aufrufe
    frankm@nrw.socialF
    @tagesschau Was will man denn da wieder verstecken? Korruption?
  • Linux:
    Uncategorized
    frankm@nrw.socialF
    @fasnix Interessant.
