Seems like a normal, sane and totally not-biased source
  • Windows 11 finally overtakes Windows 10 [in marketshare]
    10 Stimmen
    O
    MS also recently shared that they lost 400 million Windows users. I bet most of them were Windows 10 users. This isn't "people finally moved from 10 to 11",, this is "people finally got so fed up with Windows that they abandoned it for other options" (mostly mobile/tablet but also some Linux and OS X).
  • 85 Stimmen
    mentaledge@sopuli.xyzM
    Even if it is, I don't see what it's going to conclude that we haven't already. If we do build "the AI that will save us" it's just going to tell us "in order to ensure your existence as a species, take care of the planet and each other" and I really, really, can't picture a scenario where we actually listen.
  • 45 Stimmen
    adespoton@lemmy.caA
    Most major content producers have agreements with YouTube such that as their content is discovered, monetization all goes to the rights holders. In general, this seems like a pretty good idea, and better than copyright maximalism. However, I’ve had original works of my own “monetized by rights holder” because they used my work (with permission) in one of their products, and so now have co-opted all expressions of my work on YouTube. So the system isn’t perfect.
  • 45 Stimmen
    10 Beiträge
    F
    Louisiana has been doing this for decades. It's the same old story of large corporations getting massive tax breaks while little guys gets screwed over. https://www.youtube.com/watch?v=RWTic9btP38
  • 153 Stimmen
    22 Beiträge
    Someone will have to. At our company we still have the glass seiling. But I'm pretty sure everyone knows that new people are pretty much useless so we have to grow them into someone useful. If they leave it hurts all the way up corporate. Try different companies and see if you can find one that cares. In my experience big companies really truly suck much. But they are stable for you to keep helping them. Small companies are stable and full of emotional problems. But that's my kind of people.
  • The Prime Reasons to Avoid Amazon
    341 Stimmen
    76 Beiträge
    I avoid buying from Amazon as much as possible, but good luck doing anything online and avoiding AWS.
  • NVIDIA is full of shit
    389 Stimmen
    89 Beiträge
    19 Aufrufe
    J
    Like I said...you don't know what DLSS is, or how it works. It's not using "AI", that's just marketing bullshit. Apparently it works on some people You can find tons of info on this (why I told you to search it up), but it uses rendering tables, inference sorting, and pattern recognition to quickly render scenes with other tricks that video formats have used for ages to render images at a higher resolution cheaply from the point of view of the GPU. You render a scene a dozen times once, then it regurgitates those renders from memory again if they are shown before ejected from cache on the card. It doesn't upsample, it does intelligently render anything new, and there is no additive anything. It seems you think it's magic, but it's just fast sorting memory tricks. Why you think it makes games better is subjective, but it solely works to run games with the same details at a higher resolution. It doesn't improve rendered scenes whatsoever. It's literally the same thing as lowering your resolution and increasing texture compression (same affect on cached rendered scenes), since you bring it up. The effect on the user being a higher FPS at a higher resolution which you could achieve by just lowering your resolution. It absolutely does not make a game playable while otherwise unplayable by adding details and texture definition, as you seem to be claiming. Go read up.
