Adblockers stop publishers serving ads to (or even seeing) 1bn web users - Press Gazette
351 206 1.8k
  • Why Smart Uniform Systems Are Essential for Manufacturing Plants
    12 Aufrufe
  • 575 Stimmen
    114 Beiträge
    683 Aufrufe
    a toddler giving another toddler some milk.
    11 Aufrufe
  • Apple’s plan: Stall, cheat, repeat
    215 Stimmen
    37 Beiträge
    282 Aufrufe
    E
    Why should Apple stop doing business in the EU that makes no sense. Why would they deliberately cut themselves off from a huge potential market.
  • 48 Stimmen
    14 Aufrufe
  • 77 Stimmen
    21 Beiträge
    120 Aufrufe
    G
    Because the trillions is the point.. Not security.
  • 691 Stimmen
    140 Beiträge
    614 Aufrufe
    H
    Maybe I don't want you to stop, big boy.
    33 Aufrufe
    Forgive me for not explaining better. Here are the terms potentially needing explanation. Provisioning in this case is initial system setup, the kind of stuff you would do manually after a fresh install, but usually implies a regimented and repeatable process. Virtual Machine (VM) snapshots are like a save state in a game, and are often used to reset a virtual machine to a particular known-working condition. Preboot Execution Environment (PXE, aka ‘network boot’) is a network adapter feature that lets you boot a physical machine from a hosted network image rather than the usual installation on locally attached storage. It’s probably tucked away in your BIOS settings, but many computers have the feature since it’s a common requirement in commercial deployments. As with the VM snapshot described above, a PXE image is typically a known-working state that resets on each boot. Non-virtualized means not using hardware virtualization, and I meant specifically not running inside a virtual machine. Local-only means without a network or just not booting from a network-hosted image. Telemetry refers to data collecting functionality. Most software has it. Windows has a lot. Telemetry isn’t necessarily bad since it can, for example, help reveal and resolve bugs and usability problems, but it is easily (and has often been) abused by data-hungry corporations like MS, so disabling it is an advisable precaution. MS = Microsoft OSS = Open Source Software Group policies are administrative settings in Windows that control standards (for stuff like security, power management, licensing, file system and settings access, etc.) for user groups on a machine or network. Most users stick with the defaults but you can edit these yourself for a greater degree of control. Docker lets you run software inside “containers” to isolate them from the rest of the environment, exposing and/or virtualizing just the resources they need to run, and Compose is a related tool for defining one or more of these containers, how they interact, etc. To my knowledge there is no one-to-one equivalent for Windows. Obviously, many of these concepts relate to IT work, as are the use-cases I had in mind, but the software is simple enough for the average user if you just pick one of the premade playbooks. (The Atlas playbook is popular among gamers, for example.) Edit: added explanations for docker and telemetry
