PNG has been updated for the first time in 22 years — new spec supports HDR and animation
It's great that Papua New Guinea is still receiving updates /s
I hate that you can’t right click copy images, it always wants to share as a link. Plus some other issues when sharing, but it’s just such a pain in the ass.
That’d be the browser’s (or whatever app you’re using) fault, not the format. I guess you could choose to hate it for poor support.
2029 Headline: Worlds largest data breach caused by zero day exploit in popular PNG 3.0 renderer
the payload was reportedly embedded in an animated image of the attacker repeatedly flicking his left testicle
That was because they added 'shorts' and friend-lists to it.
Right, and it depends on what "quite off target" means. Are we talking about greens becoming purples? Or dark greens becoming bright greens? If the image is still mostly recognizable, just with poor saturation or contrast or whatever, I think it's acceptable for older software.
So it depends on the specific HDR encoding used, Rec2020 is the most common ones you'll see (It's meant for "pure" setups, i.e. where the source and output are tightly linked, e.g. gaming consoles or blu-ray, or so) and the raw data won't look great. While something like HLG (Hybrid-Log Gamma) is designed for better fallback (As it's meant for TV broadcast, where the output device is "whatever TV the user has"), so should just look dimmer.
This is a HDR screenshot I took of Destiny 2, which uses Rec2020, tone mapped to SDR
And here's the raw screenshot data from before tonemapping.
If the second image had all the right HDR metadata, and the viewer supported it properly, then both images would match.
Colleges spend Millions to catch plagiarism and AI. Is Turnitin faulty and expensive tech that require students to let the company keep their papers forever, worth it?
Iran’s internet blackout left people in the dark. How does a country shut down the internet?
Republican National Convention Sued for Sending Unhinged Text Messages Soliciting Donations to Donald Trump’s Campaign and Continuing to Text Even After Trying to Unsubscribe.
Twenty-seven states and DC sue 23andMe to oppose the sale of DNA data from its customers without their direct consent
