Fairphone announces the €599 Fairphone 6, with a 6.31" 120Hz LTPO OLED display, a Snapdragon 7s Gen 3 chip, and enhanced modularity with 12 swappable parts
    Was really hoping to see a Fairphone 6a. Similar to the Google Pixel Series.
    Just a cheap version of it.
    I really don't need 120Hz, OLED or "No Bezels" all i want is big battery and a headphone jack that is all.
  • Phishing attacks? On a headphone? 🤣
    Wired headphones can be intercepted, as the wires unfortunately also act as an antenna (I'm a computer security technician, we semi-routinely do such interception).
    As for sound quality, it will always be limited by the DAC quality, and there is little way to add a good quality DAC without adding significant weight to the phone. Did you ever wonder why audiophiles audio players looks like bricks? That why.
    But I agree with point 2, 3 and 5, they are valid, but I don't agree with some aspects:
    • You can make some TW headphones bips to find them, which you cannot with wired ones for obvious reasons.
    • The cable is unfortunately often their weakpoints, and I had to throw away multiple of my headphones (which were fairly good quality ones) because of that. That's actually the main reason I went wireless. I was tired of the cable breaking, and it getting in my way.
    Now all my audio equipments are wireless, and I change their batteries every 5 years or so. Unfortunately I bought mines before Fairphone launched theirs, so it wasn't an option, but once any of my headphones eat the dust for good, I'll probably buy an easily repairable one if audio quality and codecs are acceptable (I'm an Audiophile, so that's important to me).
    Phishing attacks?
    Yep. There was a type of attack that utilized wireless headphone merging as an attack vector. With wired headphones, you can simply turn Bluetooth off.
    I know of DACs (been through audiophile phase myself), and sure, a typical integrated mobile one doesn't deliver THAT big of a quality. Still, wired headphones are not bottlenecking much just by the means of connection. And they are generally cheaper for the same audio quality, because you don't need to put batteries etc.
    Agree with your counterpoints. On the cable - I much prefer detachable options, so you can replace the cable easily. but the connector has to be strong enough - I'm a bit tired to see my Moondrop Chu disconnecting and shaking somewhere in my pocket.
  • Exactly this, that's a lot of space taken up to connect what 4 analog wires?
    That's insanity when a AUX to Usb-C converter does the job
    USB-C requires a lot of space for charging, data transfer etc.
    Let's remove it too and make phones rely on wireless charging instead.
  • so you need a dongle for the DAC, and an additional dongle for charging that is also, if I recall it correctly, violates the USB-C standard. did I understand it correctly?
    Sure, for simplicities sake let's just say it's impossible.
    How many times has the average person needed to do so in a year?
  • Thank you, this is huge!
    I was very, sad to miss out on the entire Fairphone 5 generation, but I gave up and bought a Pixel 8 when they announced the 5 wont be coming any time soon.
    Finally I can get a phone that's worth buying (and earbuds as I see they carry the fairbuds now)
    Please take note of MystValkyrie's response to my post. I have no experience with Murena and I cannot vouch for them. In light of what MystValkyrie shared, it might be wise to proceed with caution and maybe look into it more before ordering.
  • You are genuinely the first person I've seen online who understands screen size != Phone size, because bezels exist and are different sized from phone to phone.
    My current 6.3" screen phone is virtually identical in size to the 4.2" one I had in 2012.
    Bezels or not phones are still too large to be comfortable to use for many people.
    5.8" with no bezel would be a great size. Something comparable to an old 4-4.2" phone.
  • Plus I don't want to have a dingle I can forget when in a rush.
    Just have the dongle permanently attached to your earbuds like it's a part of the cable.
    Awesome solution. Remove the port that everything used to have and make consumers buy adapters. I have like 5 headphones. Should I go buy an adapter for each one? Not to mention that I can easily fix a headphone cable but if a 3.5 to usb-c adapter breaks, it basically becomes junk.
  • That means the audio still goes through another DAC, lowering the sound quality, compared to an analog 3.5 jack. Also, who wants to further risk wearing out\vreaking their charge port, jack inputs almost seem like they can't break.
    Technically it only goes through 1 dac, not "another one". But still, yeah, your phone's dac is most likely a lot better than the one on a $10 adapter. However, the usb-c spec does allow an analog audio signal passthrough. Whether that's available or not depends on the phone I guess.
  • You'd ultimately be sacrificing battery size for that Aux jack you hardly use. For most that's not worth it
    Not really, no. There are even people that have been able to ADD a headphone jack to iphones that don't have one.
  • Probably not a popular thing to say on here, but I think you’ve lost the battle for the earphone jack. It probably just requires way too much real estate to be practical on a modern day cell phone.
    It absolutely does not. That's just the stupid propaganda companies distribute to make people buy wireless earbuds.
  • Technically it only goes through 1 dac, not "another one". But still, yeah, your phone's dac is most likely a lot better than the one on a $10 adapter. However, the usb-c spec does allow an analog audio signal passthrough. Whether that's available or not depends on the phone I guess.
    Too bad LG got out of the phone biz. They had the best dacs and some good phones.
  • Honestly, I don't really get the people who complain about the lack of 3.5mm jack on a smartphone. If you're looking for quality you're more likely to get better quality out quality USB-C headphones than quality 3.5mm headphones due to the USB-C headphones picking up less noise and having its own DAC (which is probably better than the phone DAC that 3.5mm would use).
    EDIT: I would've been surprised if this take wasn't controversial. But I guess it's a good example how the fediverse is not a leftist echo chamber. You have a loud minority complaining about not being able to use a century old technology that the vast majority in the mobile space has moved away from and any compromise on what you want is unacceptable. That's about as conservative as you can get.
    You are completely and utterly wrong. I'm pretty sure that a $700 phone's dac is better than what you can find on a $5 dongle from god knows where. Also, by design there should be no "noise" or "interference" causing issues with the internal dac. If there is, you bought an extremely shitty device.
  • Let me expand, as I usually deal with surveys and population feedback. There's loud feedback, and there's statistically significant feedback.
    People who want a headphone jack are very loud. They will interject this issue into every feedback opportunity given. They will mention it on the comment sections, forums, q&a sessions, answer their surveys accordingly, etc. That's all fine and their prerogative.
    However, when you look at the statistics. They are unfortunately a very tiny minority of the entire population. They are not statistically significant for decision making. They don't have the volume to move sales significantly. This sucks, of course, and I personally wouldn't mind the return of headphone jacks, smaller phones and bigger batteries as a fair trade for thicker phones.
    But unfortunately, the vast majority of the market is pre-occupied with other things. The phone screen is too small, the phone weights too much, the phone is too thick, I want to bring my phone to the pool without fear of it breaking, etc. They are not as passionate about it, not like the headphone people are, but they far outnumber them in several orders of magnitude. In the end, if the product doesn't sell, it won't matter how much it was worth to a single passionate person. It will sink the company if it doesn't have mass appeal. Making phones is already an extremely expensive endeavor.
    You know why there aren't more users complaining about this? Because they flat out did not buy the device for that reason (e.g. me). Removing the jack is also extremely hyprocritical coming from a "sustainable" company.
  • Okay, I'm going to ask... why don't you use wireless?
    Edit: some results are in, and the only reasonable answer is better audio quality, although that's probably no longer true. The rest are fairly weak reasons.
    Lol'd at the 10m extension cord though, thanks for that one.
    Let me give you simple example. When I take a flight, I like to watch my own media. Those flights sometimes are upwards of 10 hours. If I use wireless earbuds, both the earbuds and my phone will run out of battery and I have to charge them separately. However, since I have a phone with a headphone jack, my earbuds never run out of battery, I can charge my phone while I'm using them and I don't need to use a single adapter.
    Oh yeah, and the audio quality is also better.
  • Compared to the Fairphone 5 it has some improvements but also a few downsides:
    Pro:
    • It's a bit smaller (~4mm) and lighter (~20g)
    • Slightly better camera (future tests will tell how much better)
    • 120 Hz display
    • More RAM and storage (although I feel that the previous 6GB/128GB option was also sufficient for most users)
    • WiFi 6E Tri-Band (however you will likely never need this speed)
    • Bluetooth 5.4
    • Slightly larger battery
    Con:
    • Backpanel now requires a screwdriver
    • Display has less resolution/PPI
    • Performance of processor will likely be nearly identical to predecessor (however it's more efficient and modern)
    • Downgrade to USB 2
    • 600€
    My conclusion:
    Overall the improvements are ok, however just releasing the Fairphone 5 with a newer SoC might have been the better/more cost effective choice.
    Sacrificing display resolution for 120 Hz feels also quite wrong.
    600€ is very pricy for a phone like this. Cutting some premium features away like the 120 Hz display or a bit of RAM and storage (that you can extend anyway with an SD card) might have saved enough to get the launch price down to somewhere near 500€ which would make it accessible for a wider audience.
    The extra RAM and storage probably increased the price much more than the screen upgrade.
  • What's the use case for microSD slots on phones these days anyway?
    If it's (just) to avoid paying Google or Apple storage fees, you can work around that by buying one or several HDDs to keep at home and sync stuff over the local network, possibly even build a server and access your stuff remotely.
    I really don't understand the need for that much space on the go, though. Are you watching entire series on your phone?
  • I've never met someone that cared about a thinner phone, they've been too thin since 2015..
    People that want their ducking hradphine jacks? They are everywhere.
    This is thing with not understanding how statistics work. The point is that your personal experience is biased.
    These people are not passionate about phone thickness. They won't start or even have conversations about it. Specially since, for the most part, the companies are already catering to their tastes. But, if placed in front of a survey and asked to rank phone features by their importance for their purchase decisions, the overwhelming majority will rank other phones features way above a headphone jack. Most people on the planet are not audiophiles, and the majority of people perceive wires as an annoyance and an inconvenience.
    That is the point of surveying and market research. To check with the actual potential buyers what is worth making. Of course it isn't a guarantee, looking here at the recent flop of the Samsung Edge. But otherwise, a single person's perception of the market will never be complete or accurate.
    Pro:
    • 120 Hz display
    • Bluetooth 5.4
    Con:
    • 600€
    My conclusion:
    USB 2? What a stupid choice that appears to be. Did they have any reasoning behind that?
  • Worth noting buying a second hand phone is still better in every aspect and sadly 2nd hand Samsung from 3 years ago is still better and cheaper. Though Fairphone is getting closer with each release!
    Cheaper? Yes. Better? Hell no, unless you can root it and install a custom ROM.
    I bought an oled phone for 200€ a few years back. What I'd really want is that every smartphone sold in the EU is open, with open drivers and OS with root access if you want to. And some investments by the EU to support open smartphone OS.
    What a shithole civilization.
