Giving Up on Element & Matrix.org
I agree with all this. The thing which caused me to uninstall was suddenly being pushed lots of abusive message with disturbing contents.
When I complained about it, Matrix told me that my public complaints were hurting the ecosystem and I should be quiet.
i want 90s era icq and 2000s era msn back
But they both closed source protocols locked down to specific corp
What would you propose, then?
NeoChat on KDE allows me to choose which account to login to when I start it.
Does it let you be logged in as both ?
I just want a self-hostable open-source alternative to the shitty closed-source IM systems I'm forced to use
I'm sticking with Matrix for now, hopefully some of the issues I've had will get ironed out
How about jabber/XMPP
I am still mad that are no mobile clients that supports multiple accounts. So I am ending up installing for each account a different client.
Edit: added mobile.
Element Desktop has profiles. But sadly there are no profiles on the mobile app.
Edit: added mobile.
XMPP is still an option
Weird. I think they did some improvement to prevent those abusive messages but it took a while and it was embarrassing. Maybe it's hard to prevent them with a federated network but still, the abusive messages where basically a copy paste.
Edit: added mobile.
Fluffy chat allows multiple accounts
I wish xmpp was p2p. I can self-host but it could be way simpler if people didn't have to.
I wonder if Keet with every be open sourced. They still are missing a lot of features that I personally find important like trying notification, read receipt.
Edit: added mobile.
I see what you did here. Say something wrong on the internet to get multiple helpful tips.
The thing is... What alternatives are there? Signal can't be trusted (on the very same website there is an article about it). I'm not using closed source alternatives, Simplex is kinda shady too tbh and I'm not even sure I could get anyone to use it.
I don't like Matrix/Element either but sadly its the best open source chat solution we have.
The article author went back to XMPP, which does appear to be the best option currently.
I like this client. Thanks for the tip.
GitHub - matrix-construct/tuwunel: Official successor to conduwuit
Official successor to conduwuit. Contribute to matrix-construct/tuwunel development by creating an account on GitHub.
GitHub (github.com)
Plug for tuwunnel.
Easy to set up, and just works. I can't share any of the OP's annoyances - everything is fast. Admittedly, I don't really use the web client. Just the Android app from F-Droid and the linux AUR package element-desktop.
xmpp mentioned, I'll add IRC
I forgot to add nextcloud talk!
