Startups and Big Tech firms cut hiring of recent graduates by 11% and 25% respectively in 2024 vs. 2023, as AI can handle routine, low-risk tasks
    10 Aufrufe
  • Big Brother Trump Is Watching You
    11 Aufrufe
  • The End of Publishing as We Know It
    50 Stimmen
    10 Beiträge
    45 Aufrufe
    beejjorgensen@lemmy.sdf.orgB
    Lol.. I wanted "DRM". But it's been a long day.
  • FuckLAPD Let You Use Facial Recognition to Identify Cops.
    411 Stimmen
    11 Beiträge
    86 Aufrufe
    R
    China demoed tech that can recognize people based on the gait of their walk. Mask or not. This would be a really interesting topic if it wasn’t so scary.
  • Here's your first look at the rebooted Digg | TechCrunch
    110 Stimmen
    59 Beiträge
    242 Aufrufe
    Digg has been basically dead for 15 years.
  • Mega-BUNDLE Offer
    23 Aufrufe
    Unlock the ultimate toolkit for entrepreneurs, marketers, and content creators with the AISellers Mega-BUNDLE! This all-in-one package is packed with cutting-edge AI tools, templates, and automation workflows designed to skyrocket your productivity, simplify your sales funnel, and grow your online business—faster than ever before.
  • Building a slow web
    175 Stimmen
    37 Beiträge
    197 Aufrufe
    I
    Realistically, you don't need security, NAT alone is enough since the packets have nowhere to go without port forwarding. But IF you really want to build front end security here is my plan. ISP bridge -> WAN port of openwrt capable router with DSA supported switch (that is almost all of them) Set all ports of the switch to VLAN mirroring mode bridge WAN and LAN sides Fail2Ban IP block list in the bridge LAN PORT 1 toward -> OpenWRT running inside Proxmox LXC (NAT lives here) -> top of rack switch LAN PORT 2 toward -> Snort IDS LAN PORT 3 toward -> combined honeypot and traffic analyzer Port 2&3 detect malicious internet hosts and add them to the block list (and then multiple other openwrt LXCs running many many VPN ports as alternative gateways, I switch LAN host's internet address by changing their default gateway) I run no internal VLAN, all one LAN because convenience is more important than security in my case.
  • AI will replace routine — freeing people for creativity.
    42 Stimmen
    14 Beiträge
    61 Aufrufe
    G
    So you are against having machines do the work of blue collar workers? We should all be out in the fields with plows instead of using a tractor and assembling everything by hand in factories?
